Question about Kenmore Elite HE4 Electric Dryer
2 year old Kenmore Elite Front Load Dryer makes loud squeaking
Noise for first 5 minutes of cycle, then noise stops and it proceeds as normal. Is this the belt or something else and can we fix it ourselves vs a $75 visit fee plus time and parts?
  • Anonymous Mar 29, 2014
    How do I open the front load dryer to see if the squeeking is a belt, tensioner, or bearings?
    Sergeant:
  • 311 Answers
We can fix this. your dryer has some wheels/rollers and an idler pulley they get worn and or plug up with fabric sheet guu.what you do is pop the top,that the frount off and this will expose the drum,undo the belt the clean inspect /oil and replace worn parts.sounds like you wont see much wear because it stops after[gets warm]so may get buy with oil/cleaning Ps unplug before working
Posted on Dec 31, 2008
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
Our bosch dishwasher stops at 1 minute on screen and never advances Since we believe it is under 5 years and the electronic panel should be covered, how should we proceed Model SHE44C06UC/40 Serial...
You need a new microprocessor. Same thing happened to me. Normal cycle runs down to one minute and stops there, running, for maybe another hour or more. Then, when it finally ends, the dishes are not clean or dry. Get the microprocessor replaced. It is Chinese junk. It is an easy fix, but the replacement will last only four or five years.
Sep 03, 2010 | Bosch Dishwashers
My Whirlpool Gold dryer makes a high-pitched squealing noise for about 5 minutes when first turned on, then stops and dryer continues cycle. The noise doesn't sound like metal on metal but more like a...
CHECK BELT,TENCHEN ARM (KEEPS BELT SNUG),ALSO ROLLER WHEELS...
SOMETHING IS GOING BAD BUT ONCE IT WARMS UP IT STOPS MAKING NOISE.
YOU NEED TO FIND THE PROBLEM BEFORE IT BREAK DOWN???
LATER FREDDY
Feb 11, 2010 | Whirlpool Dryers
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Dryer motor has trouble starting
sounds like you are having or go to have a motor problem repl/ motor
Dec 29, 2008 | Dryers
Loud noise and not kneading
No, not normal. Your belt is probably gone.
Feb 20, 2008 | Sunbeam 5890 ExpressBake Bread Maker
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
336 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
