Purchased the extension loud ringer and have tried plugging in to several different phone outlets along with a phone jack "splitter". Nothing works. Is there something else we need to do to get this to work?
SOURCE: I have a Norstar Meridian with M7310 phones. When
sounds like your telephones not programmed for handsfree.
Programming is done on 7310, 7324 and 7316 type sets.Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
To clarify, this is an external ringer used in industrial shop environment, not a separate extension.
Can anyone tell me if the phone itself needs to be programmed to allow an external ringer? Or is this something that must be set up with the phone company?
Maybe a bad splitter, you didn't mention make or model # of the ringer you purchased so its difficult to answer.Did they not come with instructions?
