Computer boot up
Computer freezes on 2nd page of text during boot up or nothing happens and the light on the monitor button goes from green to amber. Cleaned the fans on the motherboard & power supply. It was good for a week. Once it gets going, I can run the computer all day without problems. Computer is old.
    Problem Solver:
  • 5 Answers
This looks like a problem with you video card drivers. I had this problem last week! ;o) The screen turned off while in the Windows logo.
You need to boot in safe mode and reinstall the drivers of your video card.
TO BOOT IN SAFE MODE :
Boot your computer and tap F8 every seconds. If you get to a blue "boott selection screen", press ESC, and restart pressing F8 every second. You will get to a black windows selection menu with the arrows. Select the boot in safe mode option and press enter.
ONCE IN SAFE MODE:
In XP, once in safe mode, you PC will boot with minimal settings and default drivers. Go to START, CONTROL PANNEL, SYSTEM, HARDWARE, DEVICE MANAGER. You should see your display adapters in there. If one has a yellow exclamation mark, then you need to re-install the drivers.
TO REINSTALL THE DRIVERS:
You need to find the graphic card CD you had when you purshaed it, or download the drivers on the internet. Go to a friends house, and download them on your manufacterer's website (ie : ASUS, ATI, etc.). You need to know your card's model name for that. It should be in the Device Manager, where you looked earlier (Ex: ASUS MAGIC 128MB)
Once you reinstall the drivers, you should be ok.
Worked for me. It makes sense because the screen turns off when it tries to load the currupted drivers.
I hope it helps.
Posted on Dec 31, 2008
Computer turns on won't boot fan runs fast
Are you getting any video display before the amber light goes off?
Aug 16, 2014 | HP Compaq Presario SR1830NX PC Desktop
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
What is happening when computer light (when
cable connection issue between computer and the display? Adjusted the cable? Tried another monitor? Safe mode works? If safe mode works, you can try to update the driver of the graphic card.
Jul 08, 2010 | Dell GX280 Optiplex 2.8GHz Desktop...
Monitor goes to standby after booting up.( Amber light)
I'm going to guess that your monitor has different imputs and maybe you aren't selecting the right one? There is usualy a button to change imputs on the monitor. If there is no signal and you've checked all the channels, the cable your using might not be functional or your monitor might be broken.
Apr 18, 2010 | HP mx705 17" CRT Monitor
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
