Question about Epson Stylus Photo R300 InkJet Printer
EPSON R300 I keep getting the Error messge: Close the cd/dvd guide. Even though the guide is closed. last week I had to push the guide tight into the printer in order to get it to work, but now it wont start up or work. Everytime I turn it on the error message comes up. Does this mean the sensor is blown? How do I fix it? Anyone know?? Cheers!Austin
  • 4 more comments
  • Austin Plan May 11, 2007
    Thanks a million friend! Just got the manual;...hope its not to techy
  • meinit Jan 12, 2008
    any one fixed this problem?????
  • Anonymous Jun 07, 2008
    error message close cd dvd guide although it is closed
  • gor_di Jun 11, 2008
    My printer says..Paper not loaded correctly
    and my computer says..Paper not loaded correctly close dvd guide
    It was working perfectly then during a print run this came up
  • juniord Jul 07, 2008
    I keep getting the Error messge: Close the cd/dvd guide. Even though the guide is closed. last week I had to push the guide tight into the printer in order to get it to work, but now it wont start up or work. Everytime I turn it on the error message comes up.How do I fix it?
  • Andrew Gardner Mar 06, 2012
    I have same problem and have confirmed sensor is at fault. Where do you get new ones? Have tried just about everywhere.
  • 3 Answers
I have the r300 manual if any want it . obd 2 @ hotmail.co .uk
(take out the spaces) its about 10mb
Posted on Jan 12, 2008
  • Epson Master
  • 691 Answers
If you had to push the tray up hard, it could just be that the sensor is now mis-aligned and not detecting the draw is closed. You can check the voltages from the sensor to determine if the sensor is switching. Get yourself a service manual for the printer (aaprox £3.50/ $7.00) to help you get to the sensor and test it's funtion. Try http://www.TheServiceManualShop.com or http://mikeburton.tradebit.com/files.php/1003
Posted on May 04, 2007
R300 error message close cd dvd guide the guide is closed but it will not print
Have you contacted Epson directly? I had a problem with the R200 some time ago and it was down to the tracking of the CD/DVD tray being out of alignment. Due to cost of the printers now it is not worth paying to get them fixed. Lookout for Epson deals where you can trade in your old R300 for a newer model. I still have my R200 still going strong and an RX858.I am sorry I have no firm advice to fix it direct.Mac#
Oct 25, 2011 | Epson Stylus Photo R300 InkJet Printer
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
Is there a button for to close the CD/DVD guide? Your Printer stays on CD/DVD printing mode, that's why
Use it. IF NOT Reset the all settings, Check for your userguide Troubleshooting.
Check epson support page for helfull links.
Aug 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Espon 1400 prob. with vista close the cd/dvd guide. It is CLOSED!
I am having the same problem. I am on my 3rd printer from Epson in 2 weeks.
The solution may be to buy another brand, but I have more in Epson ink & paper than I have in the printer.
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Nov 16, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 printer cd/dvd tray
you can try and reset the printer if you dont have the tool let me no
Nov 15, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson 300
It sounds that there is a possible hardware failure concerning CD/DVD guide cover. We can try this to resolved that issue:
1. Turn off the printer.
2. Close & open the CD/DVD guide cover for three times and make sure that the CD/DVD tray is not inserted.
3. Close CD/DVD guide, Turn the printer on. If printer is ready, press the maintenance button.
4. Try printing again.
If the above step wont resolved that issue your printer may need to send to a nearest Epson Authorized Service Center.
--->>> Tirzo
Jun 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Error message
Simply open and close the door.
Look in the LCD is the door indicator off?
Jun 01, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
788 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
