Question about Megatech Cosmic Flyer Radio Control Airplane
On my cosmic flyer the power is very weak, and does not last long
  • 39 Answers
This sounds like a new battery. check hobbylobby.com, your local hobby store or possible hobbyzone.com
Posted on Mar 29, 2009
How do i get my htc flyer off of safe mode
Hold the power key down and select restart instead of power off. Takes about 30 secs to reload but then you are back to normal
Jun 06, 2012 | HTC Flyer 7 inch 32GB Android Tablet PC...
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Our cosmic catch has new batteries in it but will only stay on for 2-3 tosses. Then it just stops. We have tried several sets of new batteries.
Mine does the same. If you give it a smack (fairly hard) on the side opposite the batteries, it "fixes" it. You should be able to then turn it on. It may have something to do with the battery connections. You could try putting some aluminum foil on the negative side of each battery to help make a more snug connection. That said, it could have to do with a lose wire inside the ball itself. In which case, you should see about exchanging it.
Nov 27, 2009 | Cosmic Pet Hasbro Cosmic Catch Game
Where do you put the batteries in a cosmic catch ball? Is it the thing that says push? Or is there another place you put them in?
For those who need answers now regarding batteries, if you look at the button, you'll see two Phillips screws recessed deep in the ball. Get a long screwdriver and unscrew them. The button panel will come out and the batteries are there. Sometimes you may need to remove the batteries to reset the thing, too.
http://www.hasbro.com/common/instruct/Co...
May 16, 2009 | Cosmic Pet Hasbro Cosmic Catch Game
Need to know how to put batteries on cosmic catch
there is a small screw right on the ball..in a square of foam on the ball itself. batteries are to go inside the ball. hope this helps!
Jan 11, 2009 | Cosmic Pet Hasbro Cosmic Catch Game
How do you change the batterys in hasbro cosmic catch ball game
The "push" button has a small hole on either side. there is a small screw at the bottom of each hole. Use a small philips head screwdriver. Once you have loosened the screws, this whole "block" of foam will come out of the ball and you will see the battery compartment.
Dec 27, 2008 | Cosmic Pet Hasbro Cosmic Catch Game
Megatech Cosmic Flyer Radio Control Airplane Logo
176 people viewed this question
Top Megatech Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Megatech Toy Expert? Answer questions, earn points and help others
