Question about Sanyo DS31520 31" TV
Tv won't come on
Tv. was working fine last night when i cut it off. Today it will not come on or make any kind of noise with remote or tring the tv button. What could be the provlem?
Any lights come on if not check ac cord if not check outlet if not then open it and check fuses
Posted on Nov 02, 2007
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
TURNED TV OFF LAST NIGHT EVERYTHING WAS FINE. TURNED ON TODAY - NO SOUND, ONLY STATIC
The tv is on the wrong input. Try running through the different tv inputs with the remote. If you have a cable box make sure its on. Hope this helps.
May 28, 2011 | Toshiba 46HX83 46 in. Rear Projection...
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Last night I dropped the remote for my CLT1554 tv
Please reinstall batteries in remote and check.
If still does not work then remote circuit board could be damaged and new remote is an option.
Hope this info will help you.
Thanks.
Feb 14, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
No power to tv
power supply or power supply relay
Sep 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sanyo DS31520 31" TV Logo
111 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
