Question about GE Monogram Side by Side Refrigerator
Water leaking from left/freezer side of fridge that is only 2 mon
I am getting a water leak from the left side of the fridge....
  • 115 Answers
Your drain is stopped up need to take back panel off and get it thawed out and cleaned out maybe with bleach unless you have like a scunci steamer it works real well to melt the ice and blow the drain out
Posted on Dec 31, 2008
Refrigerator leaking bad at bottom after manual defrost still leaking
Ah the bottom. The drain pan is overfull and can not Handel the amount of water going into it. Normal running operation will evaporate any water left in the pan. You can pull out the fridge and drain the pan or clean up the water until it stops. Good luck
Sep 09, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
My GE fridge is leaking water on the freezer side
This would be due to the defrost drain being clogged. The automatic defrost cycle melts the frost on the evaporator every few hours and the water from that is suppose to flow down a drain tube, if the drain becomes restricted the water will leak out the freezer door. Here is a link to some instructions I put together on how to clean it out.
Defrost Drain Cleaning
Jul 18, 2010 | GE Refrigerators
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Water leaking from bottom
my GE side by side fridge leaks water from the bottom only when I connet the water filter inside the fridge. The leak stops when I remove the water filter. What could be causing this?
Jul 14, 2008 | Refrigerators
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram Side by Side Refrigerator Logo
285 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
