Question about Whirlpool Refrigerators
Start relay where is the start relay on the compressor located
  • 115 Answers
If it is a frigidaire, whirlpool, or maytag it could not have a cover but is usually on the left side the compressor when you are looking at it. It slides right off the compressor cause it is 3 straight pins it slides on
Posted on Dec 31, 2008
  • 76 Answers
The start relay is located on the compressor, and is covered with a plastic covering with a with the wires coming out of it. the relay is sitting in pins coming out of the compressor
I have a samsung side by side refrigerator side by side, and it stopped cooling. the model no. is RS2533VQXAA. what can I do to resolve this problem?
Does the compressor try to start? Pull the unit away from the wall. Located on the back is a small door that covers the control board. Remove the cover and look for any burnt spots on the board.
The problem is likely the start relay locted on the compressor. Unplug the unit, remove the wires from the relay on the compressor, ( be sure to take note of their location on the relay) pull the relay off the compressor and shake it. If it rattles then it need to be replaced. Here is the relay to order if you need it. Samsung DA35 10013Q Start Relay AppliancePartsPros com
If the relay is good then replace the control board. Here is that part to order. Samsung DA41 00134F Pba AppliancePartsPros com
Keep me posted!!
May 24, 2014 | Samsung Refrigerators
Tip
Refrigerator and freezer warm...my compressor is not running
Compressor starts and then stops.....I hear a clicking noise
I wish I had a dime for every time I heard the statement above made.
Before going into the issue we must first understand just what a compressor does and where it is located. The compressor is located (in most instances) on the lower backside of the unit. The side that is against the wall. It is behind either a cover made of cardboard or metal panel.
The compressor compresses the Freon to a gas which is then circulated through the evaporator coils
Which are located inside of your freezer section . Note the over load and relay location on the picture above.
There are three components....relay/overload/and the capacitor. This subject here is for the relay and overload. They are 95% of the time responsible for the compressor not running. Without them, the compressor will try to start and at times will run for a short amount of time. The customers complaint is usually both my freezer and refrigerator are warm. They also state ,"I hear the compressor turning on but it will shut off after a minute or two" and " I also hear a clicking noise"
The clicking sound is coming from the relay. The contacts have broken inside and they are not allowing the compressor to start. Note the location of the relay and overload on the compressor. The compressor has three prongs pertruding from the side that the relay and overload are plugged into. Simply pull them off the compressor and shake them. If they are bad you will hear a rattle sound coming from them.
When ordering your new relay and overload you will need the complete model number to ensure the proper part. See my tips and how to's at the bottom of this procedure for the link to find your model number.Here are just a few styles of overloads and relays.
How to find appliance model numbers When trying to troubleshoot or purchasing parts for your appliance the model number is the key to do
on Apr 04, 2011 | Refrigerators
Asd2522wrb04 amana side by side refrigerator. clicks like it is coming on. then goes off. nothing freezes or cold. Why?
I believe what is happening here is a defective start relay and overload. Right now I would pull refrigerator away from the wall and unplug. Next remove the cover over the compressor feel top of the compressor and if it is not possible to keep your hand there from heat tells me the compressor is trying to start. Keep unplugged until replacing the Start Relay Kit below.Most times the compressor that begins to do these symptoms can be fixed by replacing the=>
W10189190 Relay and Overload Kit
These parts can be found by removing the rear cover near floor and then pulling the cover on the side of the compressor. Click Here=> ASD2522WRB02 Unit Parts In that photo is a compressor top left of photo. Number location 13 is the cover of the part I am talking about and location 12 in that photo is the start relay and overload. If you have trouble I will be here to assist you, Thanks Sea Breeze
Sep 26, 2011 | Amana Refrigerators
There is a clicking sound like something is trying to turn on, the freezer has quit cooling and now the frig is begining to shut down what can it be?
How To Replace the Compressor Relay The compressor relay is accessed from the lower rear of the refrigerator. The compressor relay is located in the terminal box which on the side of the compressor.
Before replacing the compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced
Reattach the wire to the new compressor relay and press the relay back onto the compressor terminals. Replace the terminal cover box and plug in the refrigerator.
Aug 18, 2011 | GE GSS20IEP Side by Side Refrigerator
Fridge makes clicking sound every 60-90 seconds..freezer defrosting, fridge not staying cold.
If the clicking sound you are hearing is from the back of the refrigerator near the floor then I believe the sound is coming from the start relay that is located on the side of the compressor.
Replace the start relay with a new one and you should be good to go unless the compressor has been damaged.
The start relay is easy to replace as it just plugs into the side of the compressor. Start relays are also often very inexpensive.
Make sure to use your model number and get the factory direct replacement start relay and not a 3n1 universal start relay.
Aug 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
The compressor attempts a start up but shuts down within 30 seconds--freezer & refrigerator do not seem to be as cold as it should be
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator, the relay is located in the terminal box which is located at the side of the compressor.
cautiontri.gif Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Jul 13, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
MZD2766GES No cooling.Stat(slide) set to call.120v to unit.Lights on.No compressor operations.Manually defrost last few months.
Lets check start relay, run capacitor and thermostat. Also need you to pull away from the wall and unplug, remove cover over compressor and then feel the top of the compressor to see if warm or too hot to keep hand there. Should you need a start relay you will need=> 12002784 Relay and Overload Kit
12002784 Relay and Overload Point and Click Parts If the compressor is cool I want you to check the Adaptive Defrost control=> 12002104 Adaptive Defrost Control Sometimes these parts act like the compressor start relay and stop compressor and fans and even sometimes one or the other. The thermostat should also be checked while unplugged with an OHM meter=> 61005327 Temperature Control Here is a pdf with the locations and should you have any questions I will be here again later, Thanks Sea Breeze
Here=> MZD2766GES
Apr 16, 2011 | Maytag MZD2766GES Side by Side...
Both boxes are warm. the fan runs, and the compressor kiks on for 10 sec. then kiks off i have checked the thermostat and the door seals, both r good. what else could it b?
Im sorry but it sounds like your compressor is bad. You can try replacing the start relay it is located on the top of the compressor under a plastic cap. The cap is held on by a metal clip. The start relay is about the size of a nickel and is under this cap and attached to one of the three prongs coming out of the compressor. The compressor is located in the back under the bottom of the refrigerator and is about the size of a soccer ball and is black. Make sure you unplug the refrigerator first. I hope I'm wrong and the start relay is bad but most of the time if it kicks in for more than five seconds its the compressor. good luck
Aug 31, 2010 | Kenmore 57029 Side by Side Refrigerator
Replacing a relay switch on a Kenmore Side by Side
The start run relay kicks the compressor on. If your compressor is running this is not your problem.
There are a number of things that can cause a fridge not to cool. A bad defrost system.. Check to see if you have ice build up in the freezer, or a lot of frost. Also a bad compressor. The relay switch sits on the compressor at the back of the fridge. If you put a new relay on and it won't start the compressor you have a bad compressor. Most compressors are warrantied through the manufacturer for at least 5 years. So if it's that call the manufacturer for replacement.
Apr 15, 2009 | Kenmore Refrigerators
Location of start relay
yes that is an ok price or try coast appliance if you are in the la area ok the relay is located on the left side of the compressor is conected on a 3 pin conector you can't miss it is mounted on the compressor it self
Nov 28, 2008 | Refrigerators
Refrigerators Logo
230 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
