Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Beeps then shuts off and number 14 shows on panel
My rental homes Rinnai Energysaver 556WT has been beeping and then a little later I find the heater has shut off and the number 14 in showing on panel...I don't have a manual.
  • dougsandy Dec 31, 2008
    Yes, I found the answer to the problem in the manual- thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, on most Rinnai devices/equipment, error code "14" indicates overheating. Pls check filters or any possible blockage, dust or anything out of the ordinary.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Dec 31, 2008
  • 177 Answers
Hello and welcome to FixYa!,
For the Manual needed please go to:
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/221.pdf
Hope this one Helps: --P3NGYJ03
My rinnai energysaver 1001ft will not turn on.It has power to it but it will not power up when switched on.no lights no go.HELP;;
Hello Mark Obrien,
I searched the internet trying to get a HIT from your
rinnai+energysaver+1001ft
and all combinations there-of...
I also went on-line to a MAJOR RETAILER site & poured over their inventory of systems and parts (see below)...
Alpine Home Air Products Contractor grade furnaces heaters air...
Nothing... so:
Assuming you are talking about a heater here
If you are seeing no "lights"...
perhaps checking the SECONDARY side of your
POWER TRANSFORMER would be the best advice...
If that has the required (typically 24 volt output)
continue on to your main control board...
(looking for the Typical FUSE (usually 5 AMP)...
If the fuse is OPERATED... replace it...
f it operates again... IT is time to consider purchasing that
SPARE MAINBOARD you always wanted...
Like a YORK furnace... (verify your OWN NUMBERS)
031 01267 001A OEM Upgraded York Furnace Control Circuit Board by BDP... (PC (Main Control Board)
ALSO CHECK HERE
https://www.supply.com/rinnai-furnaces/b2098
Fuse kit
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Home Improvement
Hope this helps...
Carnac the Magnificent
Jun 25, 2017 | Rinnai Heating & Cooling
Would like a manual for the rinnai energysaver 403FT we need to set our heater up so it goes on auto and how do we regulate the temperature and set time
The model number (403FT) has either been discontinued, changed or is incorrect. However, Model # RHE309FT closely matches the heater you described and has the timer and temperature features you are wanting to preset.
You may download and print the manual from the link below for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_Energysaver_RHFE309_559FT.pdf
Hope this helps you and thanks for choosing FixYa. Cheers
Aug 15, 2011 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai 308FTR heater and the first time I
Means failed ignition/no gas.
Check gas supply.
Mar 05, 2009 | Heating & Cooling
Max temperature for Rinnai 556WT restricted to 74 degrees
There is no way to restrict the setting and keep it UL approved. If you cannot get the heater above a certain setting you have either too small of a heater, too much outside air entering the apartment or the gas pressures are not great enough.
Oct 25, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai energysaver 1004F
Sorry friend!
I think this is it.
www.rinnai.us
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
109 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
