Question about Philips GOGEAR SA6045 MP3 Player
My sa5245 cannot be turn off,it is hang,pls help whether restting
Will i lose the data stored...if reset
  • yvon lecavalier
    yvon lecavalier May 11, 2010
    explain me more i have one me too !!!
  • 8,596 Answers
Upgrade the firmware to prevent the freezing issue - it is available for free on Philips website.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
It keeps saying unfortunately keyboard has stopped
First think I would do is a factory rest. This will rule out if there is an actual hardware problem.
Through this procedure, user can wipe off all the files i.e. data stored on the tablet. Along with the data, the malicious programs which are making the tablet to hang will also be wiped off. So the tablet would be afresh and will be new to use.
To reset this tablet, you have to hold the power button to turn off the device. Now you have to turn on the device by holding the power button and also the volume up button simultaneously. When you hold these two buttons simultaneously, you will be able to get a new menu. In this menu, there will be option for resetting the tablet.
You have to select this option for resetting the tablet. This will ask you whether you want to confirm the reset of the tablet or not. If you confirm it, the data stored on the tablet will be wiped off and the tablet gets formatted. Now, the tablet will reboot automatically. After the reboot, you can notice that your tablet will be afresh and will be similar to the time when you have purchased it.
Thanks,
Rising Son
Feb 12, 2014 | Techno Source Kurio Kids Tablet With...
After i download some balckberry application my phone runs slow and i turn off it then when i open it was hang and cannot access anything
Hi carol,
Have a great day.
We have the same dilemma regarding on downloading application on Blackberry phone.
I just followed this simple tips:
1)Reset your phone, do this only if you are ready to lose all your stored data.
2)Try to remove the battery and turn on again.
Hope it helps.
Thank you for using fixya.
Sep 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 9300 is hanged.what should i do ?
laharm,
Here are some options:
1)try removing the battery and turn on again?
2)phone reset, do this only if you are ready to lose all your stored data
Aug 20, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
I HAVE A PROBLEM SAMSUNG GT-C3303 IS HANGING PROBLEM PLEASE SOLUSTION THIS PROBLEM
If you have so many files stored on your phone,This will let your mobile hang,Erase some data first,mostly messages,photo,video etc. or transfer all files on your memory card.
If the phone keeps hanging more often,then your can format or reset your phone by typing this codes *2767*3855# ,if ask for the code,enter 00000000 ( 8 zero's) or if changed,enter your desire code,a message pops up that the phone will be rest (eeprom reset).The phone will take a minute or less on this process,wait until the phone restarts,then that's it,your phone back to original default settings.
Remember that this method will erase all data of your phone,so back up all important files first before proceeding.
Good Luck....
Jul 10, 2011 | Samsung Star GT-S5233 Cell Phone
After installing sinfuliphonerepo in the cydia on my iphone 3gs,suddenly iphone logo appeared and hang up,i pressed the home and power button at the same time,after booting hang up again as it is..anybody...
Hello. I'll be happy to help. More than likely, you will need to reset your phone in iTunes. If you have your SHSH saved, you should be able to download the version of the OS that you want from here. I assume that you want to rejailbreak, and you should be able to do with with Pwnage Tool or Green Pios0n. Please note that unless you have your phone backed up, you will lose all data. If that is the case, you can likely recover photos and other data after the fact using the info here. Make sure to backup your Cydia apps with Apt Backup (you can find it in Cydia), and do periodic backups through iTunes.
Feb 27, 2011 | Apple iPhone 3GS Black (16 GB)
Can't log on
where you able to perform the reset? if you wheren't then use a small pin or a needle to press the reset button.
if it sitll doesn't help you may have to perform a hard reset, it should fix the problem but you will lose all data stored in the memory, but everything on a storage card or safe storage / permanent storage will stay.
how to perform a reset or a hard reset:
http://www.hardreset.eu/hp_ipaq_h5450_hard_reset_soft_reset_en.html
May 29, 2009 | HP iPAQ H5450 Pocket PC
Touch screen problem
pls reset ur device like this if it doesnt help then u have to get ur digitizer replaced also called touch panel
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Apr 07, 2009 | HTC Touch P3450 Smartphone
N73 hangs/works too slow
My N73 M phone hangs, sometimes doesn't ring and takes 15-20 secs to navigate between functions. Pls help with a solution.
i have already reset the phone by using the *#7370# code, but it still remains the same....
Help me with a solution.....
Mar 30, 2009 | Nokia N73 Cellular Phone
Using a paerclip to trigger the reset hole will not erase any of your songs.
If that fails, however, and you have to upgrade the firmware, you will lose all of your songs
-Tha Mp3 Doctor
Dec 31, 2008 | Philips SA2310 GoGear Mp3 Player
HP IPAQ 6315 Auto Hard Rest
my ipaq6315 shutsdown and resets,i keep losing data...help me pls
Dec 04, 2007 | HP iPAQ h6315/h6365 Pocket PC
Philips GOGEAR SA6045 MP3 Player Logo
64 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
