Question about Bose Lifestyle 48 System
Can i get a replacement DVD drive for Bose lifestyle 28
The actual dvd was broken
snakehead
  • 1074 Answers
SOURCE: Bose Lifestyle 28 not playing DVD
my brother i am not familiar with that model but due to my electroincs experience all dvd players are make up of the the same principle.there is a flat strip that leads from the lens of your dvd player kindly remove it and replace it this strip is probably broken after doing this get a dvd lens cleaner and clean your dvd lens and your on if you cannot do it your self take it to a tech os that they can handle it.this job should cost about $75.00 US. enjoy Henry Thomas from Belize
Posted on Mar 14, 2007
SOURCE: Bose 321 DVD drive failure
Found another help site similar to FixYa where a person had posted that they successfully replaced their failed DVD ROM drive in their BOSE 3-2-1 Series I unit with a later model Toshiba SD-M1712 drive. There are 2 plastic trim bits and the metal DVD drive unit cover that need to be swapped between the old drive and the new PC type drive to complete the repair. I located and ordered a new drive and spent last evening removing the old drive from the BOSE. To remove the old drive all that is really necessary is to remove the lid from the BOSE unit and pop off a black steel holdown assembly across the top of the failed drive. Once that is done the old just drive lifts out and the replacement is virtually the same as swapping out a drive in your PC. I am awaiting arrival of the replacement OEM drive ($25) from some place in Texas. This just may work. BOSE wants hundreds of bucks and several weeks to repair their crappy unit. I will never purchase BOSE again. I had to also purchase a power supply in years past for this very lightly used unit and that was $300 and a lot of aggravation using the BOSE repair system. I have trouble just throwing this unit away because we spent $1000 hard earned $'s to buy the "best". I was certainly fooled. If this doesn't work I'm only out $25.
Posted on Dec 10, 2008
SOURCE: HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Posted on Dec 28, 2008
realmacoi
  • 18 Answers
SOURCE: bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Posted on Apr 08, 2009
cjackHD
  • 71 Answers
SOURCE: I just replaced the dvd in my bose lifestyle 28
Replaced the DVD? Did you replace the mechanism, or the entire media center? If you replaced the dvd mechanism, you might be out of luck getting firmware to support the rest of the hardware. If you mean that you replaced the media center, the firmware is available as part of a normal software update disc through Bose. To check sw and fw-> when the system is off, press and hold 'enter' on the media center and tap the 'store' button until you see "console sw" on the display. Same with fw.
Posted on Jun 21, 2009
I can't open my dvd
Unplug the system and retry.
Aug 29, 2016 | Televison & Video
Whch dvd drive can i use to replace for my Bose lifestyle DVD drive
Seek tech support. you can't replace it by yourself, without through knowledge in electronics.
Jun 04, 2012 | Bose Lifestyle 35 System
Vcr tape keeps ejecting, won't play
There a few things that can cause this, bad loading sensor, the idler assembly is defective, or a broken drive belt, to find the actual cause you will need a tech to see if it can be remedied at a reasonable price.
Feb 28, 2011 | GoVideo Go Video DVD/VCR Combo
I have a bose lifestyle 28 system. The DVD/CD player is broke is there a way to replace the receiver without buying and new system?
You should be able to connect another external DVD/CD player into its' auxiliary connection if it has one..
Dec 14, 2010 | Bose Lifestyle 28 System
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
I don't have a picture and the DVD sometimes will not even play. What can I do?
If it is a real DVD, try other DVD's to see if they are working. If none of them work, try to see if you can get a warranty replacement on that TV because it's broken. If you are using a burned DVD, there is a good chance that that player won't read many burned DVD types. If you are trying to play a file that you burne onto a DVD and it isn't an actual DVD disc but movie files stored on a DVD then your player isn't playing the fie because it does not have the required codecs to play the file.DVD players that have DivX codecs usually solve this problem. And for 30 bucks at walmart, can't beat it...!
Dec 20, 2009 | Televison & Video
My built in dvd player is not recognising my dvd!
If it is a real DVD, try other DVD's to see if they are working. If none of them work, try to see if you can get a warranty replacement on that TV because it's broken. If you are using a burned DVD, there is a good chance that that player won't read many burned DVD types. If you are trying to play a file that you burne onto a DVD and it isn't an actual DVD disc but movie files stored on a DVD then your player isn't playing the fie because it does not have the required codecs to play the file. DVD players that have DivX codecs usually solve this problem. And for 30 bucks at walmart, can't beat it...!
Dec 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Bose lifestyles v28 plays dvds in black and white
Check your video output settings in the menu. If you are using a composite video output and do not have the system sut up for it, you will get a B&W picture. Check your menu settings.
Aug 19, 2009 | Bose Lifestyle 28 System
Recovery dvd
Sony does not offer the recovery dvd for download. You can actually burn yourself a repair disc, which you then can use to reinstall the OS.
Just follow the instructions here http://www.istartedsomething.com/20070929/vista-sp1-recovery-disc/ for your project.
But don't forget to back up your personal data first, otherwise it will be lost for good.
Aug 01, 2009 | Sony VGN-FS740/W Notebook
Dvd player quit on my lifestyle 28
send back to BOSE and get a new mainboard,,,the problem is probably NOT the DVD player itself, but the video decoding ASIC, which burns out on thes e mainboards if the "settings" from the remote won't show on the TV,,,then you are getting no video decoding......put a big surge protecteor in next time....
Jul 07, 2009 | Bose Lifestyle 28 System
Bose Lifestyle 48 System Logo
123 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
