Question about GE DHSR333EV Dryer
Replaced element now it will not start model # dhsr333 ge dryer
My dryer stoped working... so i found the element broke.. replaced it.. hooked everything back up.. what safety switches are on this thing.. i am very good with a meter if you could give me a place to start.. or send a diagram..
  • 115 Answers
Frigidaire – built (Frig, Westinghouse, Tappan, Gibson, Kelvinator): most newer models tuck theirs above the large round element ‘pan’ behind the drum. There’re often tight ones to get to, but if you pop the cabinet top (a putty knife pushed into the front, on each side, releases the top clips) and swing it up out of the way, you’ll see it back there, next to the safety tstat. It’s the smaller round device, and its wire terminals are usually the smaller 3/16 inch ones.
GE/Hotpoint: Pre ‘Profile’ models mounted their thermal in the same basic location as Frigidaire.
One final note on these: if you find your thermal fuse (or element) open, before replacing it, be sure to check the airflow out your dryer’s vent system. Even though these devices do ‘wear out’ with age, poor airflow’s the #1 cause of failure of these devices, and if your vent’s partially clogged, a new thermal won’t last very long, but will do its job again, and leave you ’cold’ (a new element won't last long if the vent's clogged, either).
Posted on Dec 31, 2008
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
The dryer stoped heating probably the heating element right?
I had a G.E. dryer just like that and it quit heating. It WAS the heating element.
Oct 13, 2012 | Dryers
MY dryer stoped working
I need your model number to be more helpful. You can start by checking your door switch if the dryer just won't start. You should hear a click from the door switch when you open or close it. If no sound then replace the switch. If the dryer runs, but no heat, often a dryers heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a video to help you check for the problem.
Nov 26, 2010 | Whirlpool Dryers
My dryer stopped heating up so I tried to fix the heating element. I noticed in the other one that some of the coiles broke in half so I knew this was the problem. Well I bought a new one, hooked it up and...
Could be a defective element, but it also could be your thermostats faulty...give them a check.
Normally you can only hook up the heating coils one way...I do not believe that would be the problem.
Hope this helps
Sep 29, 2009 | Whirlpool LEN2000PW Dryer
HOW DO I REPLACE HWTING ELEMENT
depends on the model and type of dryer and if it's a "cake pan" re-string "or encased element there are too many variables w/o brand name and model numbers
Aug 04, 2009 | GE Dryers
HELP WITH MAYTAG DRYER DE712 DRYER HAD NOT BEEN USED FOR WEEK NOTICED THE TUB WAS HOT AS IF HAD BEEN IN USE FOUND A HEATER COIL BROKE AND AM REPLACING HEATER BUT DO I NEED TO REPLACE SELECTOR ALSO...
Hi, The element broke and shorted out against the metal on the dryer. The thermostat did not cause the element to break and will still be ok. You replace the element and you should be ok.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 05, 2009 | Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Dryer timer stoped working and so it runs and runs
Dryer knob assembly unit is faulty and loss of heat sounds like an element going out.
Dec 10, 2008 | GE DBSR453EBWW Electric Dryer
Washer wont start
your vent is prob. stoped up so the dryer got to hot a blew a thermal fuse..it is located at the top of the element housing
Apr 12, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
Dryers Logo
107 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
