Question about HP Officejet Pro L7780 All-In-One InkJet Printer
When the printer's jam and cleared it keep saying its jam
This is the second printer i've gotten it dose the same thing is there a reset button.
  • 177 Answers
Hello and welcome to FixYa!,
In Order to reset the settings to default, You will need to unplug the Printer for 10 - 30 minutes, which will Reset the printer and Hopefully Fix Your Problem!
--P3NGYJ03
Posted on Dec 31, 2008
    Genius:
  • 1,847 Answers
There is no reset button but you have to use the menu to reset it. check the manual for detail.
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Brother printer clear non-existant paper jam
There probably is one or a sensor is dirty would be the most likely culprits.
Jul 09, 2012 | Brother MFC-8460N All-In-One Printer
Had a paper jam when cleared and turned back on keeps showing Error and lights flashing?
Two possibilities - First, the jam is not completely cleared. Check to make sure there are no small bits of paper blocking a sensor.
Second possibility. You don't say what model printer you have, but some need to be reset after a jam. Check your manual to see if your printer is one of them. If so, just follow the directions. Another option is simply to turn the printer off for about 30 seconds and then turn it back on. This does an automatic reset.
Oct 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have an epson stylus photo 1400, and i did somethign stupid and jammed some paper, and i would like to know how to remove it. i can see it, but i can't grab it, and i don't know if there's any way i can...
Well first of all you can try to reset your printer -
Turn off printer
Press and hold 'stop' 'maintenance' and 'power'
buttons for about 10 seconds.
A message will appear on the screen.
power off and back on for reset.
Try the following steps to clear any jam -
1. Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
2. To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
3. For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
4. Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
5. Try printing another document.
Good Luck!!
Thanks
Oct 06, 2009 | Office Equipment & Supplies
Keeps blinking E3
Hi. Canon says this
E, 3
Paper jam.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press the Black or Color button.
There is another step to fix this, also from canon.
Issue: ERROR LED: E, 3
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Apr 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
My Hp printer keeps saying "resume".
Do a complete reset.
1- Clear the printer queue.
2- Turn off the device.
3- Remove paper in the tray and possible paper jammed.
4- Remove ink toner.
5- Turn on the device briefly and turn it off.
6- Replace paper and toner.
7- Turn on!
Mar 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
Had a paper jam. Cleared the jam.
you have go to SP mode to reset it;
1, power on,
2, press "clear mode" enter107 and "clear/stop" for few second
3, press "copier SP mode
4, turn power off (5 second) and back on.
Dec 14, 2008 | Gestetner DSc332 Copier
My canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Feb 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
PRINTER ERROR SEE DOCUMENTATION AND CALL SERVICE IF NECASSARY
Have you tried a reset. Turn off the printer and hold the reset button down while turning it back on, keep the reset button pressed for a few seconds.
Nov 14, 2007 | Epson Stylus CX3200 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
13 people viewed this question
Ben Johnson
