Question about Canon PowerShot S45 Digital Camera
Canon s45 no image to lcd from lense
My Canon s45 was working perfectly until it was dropped from a very very small heigh in a soft leather case with protection. The camera works in the sense that it can read and display the images from the SD card perfectly, the lense extends but you cannot see anything on the LCD when wanting to take a picture bar a white box in the middle that usually turns green once focussed (but now doesn't.) The screen is just black. The shutter clicks, takes the picture, but just a black LCD screen.
Any help would be appreciated
  • k_irwin296 Jan 18, 2009
    I have the same problem.
  • nchatta Feb 23, 2009
    NADEEM
I have the same problem I went to the canon service department and they told me that its a common problem and the image sensor has to be change it will cost me 160.00 depending on the area where I'm getting it done so for me it's better to buy a new one.
Posted on May 08, 2009
Lid does not seal---very loose
If sprayer doesnt seal against pressure, I suggest check cover gasket A (image 1). Check pump cylinder gasket B (image 2) and additionally, check the procedure if pump dont build pressure. on how to remoce pump cylinder on follow lines.
If pump doesnt build pressure... in most instances, failure of the pumo to build air pressure in the sprayer is due to dry or worm plunger cul leather. To work on cup leather, always remove plunger from pumo cylinder. Do not attempt to oil cup leather through breather hole in **** cap.
First, unthread pumo cap A (image 1). If cap is too tight, and if pumo will build even slight temporary pressure, pressurizing the tnak will make it easier to loosen cap. Once cap is lossened, release tank pressure. Hold pump cylinder by inserting hand through tank filler openning (image 2), and unscrew cap all the way. Pull plunger from cylinder, and remove cylinder from inside the tank.
Place a few drops of clea oil (not heavier than SAE 30) on leather, and massage into leather until it is soft. Replace plunger cup leather if damaged (image 3). to remove plunger leather assembly, use coin rather than screw driver in the slot of the plunger cup retainer. To reassemble, hold pump cylinder in tank openning, with squared edge of flange, at top of cylinder, toward tank wall.
Hope this helps to solve it.
Sep 17, 2011 | Chapin Industrial 3.5 Gallon Viton...
Hello I have a canon a490 and lens of camera is dirty, I want that clean lens but it is small and do not clean very well. please help me
Google the word "lenspen". They have two models...one of them is small for small lenses like yours. It cleans the lens perfectly and lasts for years.
Feb 19, 2011 | Canon PowerShot A490 Digital Camera
Have a brand new EOS 100D with Canon image
Have you actually cleaned the contacts or are you just looking at them and they "look" clean? Clean them with a cotton swab lightly dampened in rubbing alcohol.
Feb 28, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My canon powershot s45 works fine , until i plug it into my computer. then it wont even power up . its not my ports or cords i checked them. i dont have the manual & i think that a setting was changed or...
When connected to the PC the cameras display will blank out, this is normal. If the cameras "Communication" setting is set to "Normal" you can only download images when the cameras drivers have been installed of the bundled CD. If you change it to "PTP" (Picture Transfer Protocol), you can connect it to any computer without installing drivers. Set the camera into playback mode, press the menu button and navigate into the menu with the tools(setup). You will find it there. Good Luck!
Apr 15, 2009 | Canon PowerShot S45 Digital Camera
Nchatta
it seems like if u see icons on lcd then sorry to tell u i think ur CCD is gone it seems like , but to make it sure first get the lens checked but iam pretty sure abt the CCD bcoz it is risky in impacts and jerks
Feb 23, 2009 | Canon PowerShot S45 Digital Camera
Soft digital images/ not sharp
Wow... Yes it can be fixed but only by a professional tech. You have either slightly shifter the reflector or damaged the sensor. There is also a possibility that you have loosened the auto focus as well. It may be just a simple adjustment. If it becomes too expensive of a fix I REALLY suggest an upgrade to a 40d. They are now affordable and there is a significant improvement in the models. You lenses are also compatible.
Dec 20, 2008 | Canon EOS-20D Body only Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Vertical lines obscuring image
The matrix is dead. Probably because of an intensive light got into the lense while the camera was in night mode. It's dead. Nothing can be done.
Jul 24, 2008 | Canon PowerShot A80 Digital Camera
Canon PowerShot Dropped: Blank Screen
For Ravi, this definitely sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
By the way, don't tell Canon that you dropped the camera. Sounds like the CCD imager was about to go bad anyway, and the drop just accelerated this.
Oct 31, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
eNDi
Oct 17, 2007 | Canon PowerShot S45 Digital Camera
Canon PowerShot S45 Digital Camera Logo
144 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
