PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
My laptop is acer travelmate
By liujerick on Dec 31, 2008
My laptop is acer travelmate 3210 found in the lower part of my screen. But the sticker says travelmate 3212NWXMi found in my keyboard lower part.
Need help I updated my acer bios from here http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=2789&formid=3394&website=AcerPanAm.com/au&siteid=8116&words=all&keywords=&areaid=12.
Now my laptop does'nt boot up. What seems to be the problem? Is there any solution for this? Tia
I update my bios in windows XP sp2. I've finished the update and ask for restart but when I hit "Ok" it does'nt boot up and not entering in windows even. Need help please.
Comments:
Dec 31, 2008
- Update to my trouble. Camone311 thanks for the reply. I tried your solution but nothing happened. I desoldered the look a like watch battery and resoldered again. But still when powering on the hardisk light indicator will only lit up then after few second only the power indicator near battery indicator is in standby. No display will be shown in monitor. I was thinking flashing the bios in external programming with the original version but I dont know if this is possible.
Jan 02, 2009
- Re: Retry flashing you bios with your original bios again your missing a step along the way re trace your steps before you flashed the bios does the cmos still have the same voltage after soldering? the bios should come back. I hope the cmos chip didn't go bad.
Answer:
There is only two instructions I found in the .exe when flashing the bios. Hit the flash botton then confirm to restart when finished flashing. Then after the restart state it will definitely beep indicating board is already poweredIs but in this case it does'nt even beeb Just light up the power led then no more. Is there any way to flash the bios in dos mode using hidden service mode with keyboard shortcut? If it does'nt have then maybe the cmos chip is really going bad. Yes the voltage from the bat. after resoldering is still the same at around 2.5v
RE: Hey everybody with problems on laptops please retrace your steps in what you did before the crash . whats the last thing you did before the crash. Don't fix anything if It ain't Broken. Backup everything, get the manual of the laptop in question try downloading if you don't have. keep a cooling distance under your laptop so it doesn't over heat and cause problems.retrace everything when you Crash. Camone
Answer: I have'nt backuped the bios 1.2v because of no option found for backuping and restore after trouble. What I remember before the crash is downloaded the bios update for TravelMate 3210 then after dl. open the program I've seen and hit Flash/Update Botton some minutes after it says finished flashing reboot the computer option is popup then I hit "OK" botton.
If I mistaken flash the bios then is fine what I was expecting is a warning from the software program will say after automatically scanned my system hardware for compatibility is.... "this version is not compatible to your bios". But sadly the software does'nt have the feature so I think many user will encounter this trouble again. Hoping the Acer technical support is watching this trouble of mine. At all thanks for the replies.
Same Problem
Jan 24, 2009
-   i have the same problem as you. i also want to know how to fix it too -   sean_850430
Solution #1
posted on Dec 31, 2008
Somewhat Helpful)
camone311
Rank: Wiz
Rating: 82%, 60 votes
shut down pull the battery out try to find out where the cmos battery is . you scrambled the bios. i you can pull out the cmos battery out and can put it in again( a small watch like battery on the motherboard. ) put the main battery in again the big recharge able battery. and see if it boots up . If it does don't mess with the bios you may have the wrong version. If it aint broke don't fix it
Comments:
Dec 31, 2008
- Retry flashing you bios with your original bios again your missing a step along the way re trace your steps before you flashed the bios does the cmos still have the same voltage after soldering? the bios should come back. I hope the cmos chip didn't go bad.
Dec 31, 2008
- Hey everybody with problems on laptops please retrace your steps in what you did before the crash . whats the last thing you did before the crash. Don't fix anything if It ain't Broken. Backup everything, get the manual of the laptop in question try downloading if you don't have. keep a cooling distance under your laptop so it doesn't over heat and cause problems.retrace everything when you Crash. Camone
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
I can't boot unless I remove internal batteries and use external power source to boot up. What is... (More)
Answer
Acer Aspire 4810tz-4508 randomly shutdown and can not be turned on, even though the on-off button is... (More)
Answer
my toshiba satellite a55-s1065 power LED is coding 00001000... (More)
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , MD
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
