Question about Maytag MSD2456G Side by Side Refrigerator
Replaced water filter now icemaker not working
Had low water pressure when getting water.Replaced water filter and now the icemaker isn't making ice
  • 76 Answers
Check to see if the direction of the water flow is correct on the filter
Posted on Dec 31, 2008
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Amana ARB9058CB refrigerator water despenser weak and ice only half-sized
If your water pressure is good everywhere else in house, the refrigerator water valve is most likely causing your problem
Oct 26, 2017 | Refrigerators
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A). After replacing the water filter, the ice maker made very very large cubes and now will not work automatically. It will work...
Good day!!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Hope this information will be helpful..
Thanks for using fixya...
Aug 29, 2011 | GE Refrigerators
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker doesnt make ice even after i replaced the filter and pushed the accelerator ice. Water does come out just not making ice.
Check the ice maker water fill tube. It is probably frozen inside. Remove it. Thaw it. Dry it and re-insert it.
Jul 07, 2009 | Kenmore Refrigerators
Maytag MSD2756GEW went from hollow ice to no ice. Water dispenser works fine, good pressure, new filter, etc., fill line doesn't appear frozen. Replaced water valve to icemaker. When refrigerator plugged...
I assume the water valve you replaced is the fill valve located within the refigerator.
If so, I suggest that you check the saddle needle valve on your water supply pipe - (generally in the basement). It may have finally clogged up totally from calcium deposits.
Replacing it may resolve the problem. Even if it does not, you've spent less than 10 dollars on it and you've eliminated one of the possible causes.
Jun 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Jul 04, 2008 | Refrigerators
Maytag MSD2456G Side by Side Refrigerator Logo
166 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
