Question about Lexmark X2500 All-In-One Printer
Our printer won't feed the paper through.
How can we fix our problem. The paper starts feed through and then stops. I can hear the printer itself working. Is this worth fixing? Or will we need to buy a new printer?
  • 949803 Jan 01, 2009
    I am having the same problem as the previous poster. My printer has only been used about 5 times but, has been sitting in a shelf for almost a year. In my case, the wheels cannot possibly be worn out.
  • Lexmark Master
  • 5,568 Answers
The pickup rollers can become glazed or clogged with paper fibers reducing the traction they can apply to the paper.
I am not personally familiar with your printer so I don't know how accessible they are but they need to be cleaned or resurfaced with a compound that bonds to the surface of the rollers and restores their grip.
There is a discussion of this rejuvenator here:
Restoring rollers
Posted on Dec 31, 2008
E on screen of canon p23-dh v
SOLUTION: I was just having this problem with mines but I was able to fix it. The I don't much about any memory overload or anything (I only do simple add and subtract computations). First I removed the cover and removed the paper from the feed (its a pain I know to reload but you want you're calculater fixed right?). Next I removed the ink roller (it's marked 'PULL UP'). Then after some tinkering, nudged the numerical stamp to the left 2-3 times which immediately started the feed right up. My explanation is that the printer had gotten jammed/off track causing the FEED to stop working. You'll know it definitely if you hear a low quick hum each time you switch to the print function which is probably the little motor saying 'hey, umm I would print if I was connected to a printer!'. Happy Calculating!
Feb 13, 2012 | Canon P23-DHV Calculator
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
False paper jam on HP J6480. partial reset doesn't work? Is there any fix
When resets don't work, there is a deeper problem. The sensor for paper feed can be bad and you can tell if you hear a fast zip sound shortly after powering up. Also a paper scrap can be lodged inside stopping the paper present sensor from working. Also when paper feed is started if the roller is dirty and can't pick up paper it will report that as a jam. Take a look inside and write back if nothing helps.
Feb 19, 2010 | Office Equipment & Supplies
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Paper not feeding properly, nothing jammed as I have checked. Loading tray having problems.
Check to see if the printer is actively trying to feed the paper. If you hear it trying to feed and see the wheels turning, but the paper won't feed, check to see if a screw securing the feed wheel has come loose. If you hear the sound, but nothing moves to pull the paper in, then you probably have a bad printer. They're too cheap to replace to bother fixing - so get a new one.
May 25, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
Xerox 5310 paper does not feed
did you jus replece a pick up?
please replace it ok
Apr 06, 2009 | Office Equipment & Supplies
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Mecha error 07
Mecha error 07 and 08 are malfunctions of the paper feed pinch motor located in the right side of the paper compartment. The paper feed pinch is the first roller to grab the paper when it feeds into the machine. This error is tricky. I will walk you through a few fixes.
The first fix is to just power cycle the printer and try to reload the paper. Occasionally the pinch arm will end up in the wrong position due to the printer stopping because the ribbon was empty.
The second fix is to check and make sure that the sensor arm is reaching both sensors on the motor. Sometimes the arm binds on the metal plate inside the paper compartment causing it to not reach the sensor.
The third fix is to start replacing parts. The two things to start with would be the sensors and, although rare, the motor itself. After those are ruled out the only other options are the wiring harness running from the sensors to the junction board, the junction board itself, the power cable running from the junction board to the controller board, and then finally the controller board itself.
Sep 29, 2008 | Kodak 6800 Thermal Photo Printer
Lexmark X2500 All-In-One Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
