Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Ge Triton XL Dishwasher Fill Problem
Ge Triton XL Dishwasher Starts to fill with water then as soon as the bottom arm begins to spray water the tank begins to drain. Any suggestions???
  • 1 more comment
  • lindafruby Jan 18, 2009
    GE Triton XL Does not fill. Runs as if everything is fine, but if you open it up, there is no steam and no water. We handwash and just use the drying cycle. It was a new machine about 1 year before this problem. I don't expect that it can be fixed in an amount worth the machine. Before this one, we had a wonderful dishwasher that lasted 25 years. Of course, it used a lot of water, but I only replaced it because the coating on the rack wore away. I miss it.
  • Anonymous Feb 25, 2009
    I have the same problem. will not fill with water
  • Anonymous Mar 28, 2014
    The machine starts begins to fill with water starts humming then drains water and switches to zero on time and beeps constantly
  • 170 Answers
I would check your fill valve screen, where your water line connects to the dishwasher, lots of times i will see that screen clogged, especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it....
http://www.applianceaid.com/dish.html#filling (http://www.applianceaid.com/dish.html#filling)
this is one continuous link.....you can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
Posted on Mar 27, 2009
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My GE Triton XL dishwasher (6-7 years old) doesn't seem to be spraying water. Is this a fixable issue or is it time to replace it?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Dishwashers
Water won't come into dishwasher
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most
Apr 09, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
I bought a used GE Triton XL d/w with no manual. It worked great but now it is not cleaning anything, when the cycle is over the soap cup is open but half of the soap is still inside of the cup. I opened...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jan 22, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Dec 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishes not getting clean
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE TRITON LX Dishwasher
First check your Drain Cup filter it is just under the lower spray arm you may have something blocking the drain... if its clear check the drain pump... does it run a drain out? can you here it make noise? let me know if this helps ?
Aug 14, 2007 | GE ZBD5900D Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
391 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
