Question about Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer HE4-Panel Switch is not Working
Panel Switch is not Working.
It will work once in a while and End of Cycle is Buzzing throught out the Running.
What is Problem for this?
  • Anonymous Mar 16, 2014
    All of the sudden the dryer chimes quit working. End of cycle chime however works. Read owners manual but couldn't find solution. Held end of cycle but for 15 seconds to reset but nothing happened.
  • 91 Answers
Repl/ touch panel ,were the front push buttons are the whole assembly ,,
Posted on Jan 03, 2009
Not heating on kenmore elite he4 model 1108508
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore Elite HE4 Electric Dryer
I have the kenmore elite HE4 dryer and the cycles lights went out and are not coming on how do i fix this
Check and see if child lock is engaged first.
Press the end of cycle signal button for 3 seconds
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
If that don't work I would look for reasons why the dryer duct fuse would blow and correct that by removing air restrictions that would cause overheating.
HE dryer notes and service manual
Apr 12, 2011 | Kenmore Elite HE4 Electric Dryer
Hello, our Kenmore Elite Dryer panel isn't working . I'ts getting power but the panel is not responding.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer is not heating up to dry the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Kenmore Elite HE4 Electric Dryer
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer-model#110.95087401 keep beeping and the end of cycle lights are going on from off to high and back to off right through the drying cycle.
I had the same problem and eventually none of the cycle buttons light up or the cycle time display. So it would not run at all. After taking it apart once and fiddling with the cycle push buttons, it worked for one load then would not work again. I could see 3 of the led faintly illuminated and unplugging and plugging back in the power changed nothing. Then I removed the plastic ring of cycle buttons that is between the panel circuit board and the outer plastic. (There a several layers to get to the ring.) Now I use a long allen wrench to push on the switch on the circuit board. I left the middle start button in place. That does not seem to cause a problem. Several loads now and still working. So it looks like the ring on plastic buttons don't release from the circuit board buttons causing a problem.
Feb 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
DYRER PROBLEMS
i took the top off checked all the wiring, cleaned the back vents, and the vent tube going outside. I also cleaned the lint screen and gaurd really good, put it all back together. I also unplugged the dryer waited a few minutes and plugged back in. The dryer had a code flashing saying it lost power, I reset the dryer and it has been working great now. Evedently it must be sensitive.
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
338 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
