Question about Hotpoint Ultima WF860 Front Load Washer
Wf840 f10 error code get worse
6 times out of ten i'm getting the error code f-10, it can happen any time in the cycle usually within the first few mins
  • Hotpoint Master
  • 3,463 Answers
F10 is indicating 2 possible probs with your m/c.
1-interrmittent cold water supply, check pressure and hose.
2-water level switch not sensing correctly, possibly sticking or partially blocked.
Hotpoint recommend calling an engineer for a pressure switch prob. but there callout is £90.00!!!!!.
Plz rate my solution.
.Thanks
Posted on Dec 31, 2008
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
No picture
can you please mention your tv model
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 04, 2014 | Frigidaire Dryers
Why does the f10 code keep appearing on self cleaning fridgidaire oven? When using oven it starts heating out of control. Tends to happen when oven is being used for longer periods of time.
The thermostat is defective. It is a temperature sensor operated switch. It turns the heating element on and off to regulate the proper temperature in the oven at all times.
Jun 03, 2014 | Frigidaire Ovens
I get F7 10 error code
Hi Claude, thank you for your question! Could the error code possibly be F1 or F10? Typically error code F10 indicates that the range has detected an issue with the runaway temperature (overheating). Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the range on. Usually this will clear most false error codes. If issue persists, I would recommend contacting a professional to proceed further for an accurate diagnosis. Most likely the EOC (electronic oven control) will need replacing. Hopes this information proves to be helpful.
Jul 30, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire beeping with F10 signal
sounds like you need to get all food out and switch it off and leave the doors open and leave it for two days with the doors open ok then afther you have left it swich back on with doors closed do not open doors for 24 hours swicth on ok then it should be ok if not then its lack of gas
Oct 15, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
T.V will automatically turn on and off during the first 10 minute
With projection TV's the lamp is usually the cause for cycling issues. The lamp power supply (ballast) monitors the current drawn by the lamp and adjusts voltage to keep the current at a specific value, if the ratings fall outside of spec the TV will cycle power and attempt to correct the anomolie. If this happens too many times within a specific time frame the TV can refuse to turn on and will indicate an error code. Don't put the TV through too many retrys or you could damage the ballast too.
Lamps can cost between $200 and $400. The ballast can cost anywhere from $150 to $250 approximately. Usually the manufacturer of the TV will sell you a new bulb, but electronics suppliers often sell them for less. Most lamps are owner replaceable and easy to do, consult your owners manual.
In-home servicers can base their labor charge on the size of the TV. The larger the TV, the higher the labor cost. Do it yourself and save!
Hope this helps.
Feb 15, 2009 | Vivitek Televison & Video
Hotpoint Ultima WF860 Front Load Washer Logo
734 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
