My indesit iwc6105 washing machine is not draining at all.
I tried cleaning the filter at the bottom of the maching and got nearly 40 pints out and the mains water was switched off! Im giving up hope as have only had the machine for 4-5 months and cannot afford a new machine. Please help if you can.
  • ahmad Sep 05, 2013
    hi my indesit stopped working and i replaced the motor bushes and three days later it stopped draining the water
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
See this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
my indesit iwc6105 washing machine is not draining - 10_12_2012_11_04_58_am.jpg
Posted on Oct 12, 2012
SOURCE:
wagdom
  • 64 Answers
SOURCE: Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Posted on Oct 31, 2007
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Same thing Happened to me I found that there was a small coin caught up in the filter..
Posted on Aug 31, 2008
barkencoa
  • 3463 Answers
SOURCE: Hi i have an indesit
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Posted on Jan 30, 2009
  • 57 Answers
SOURCE: My Indesit WIXE127 is displaying error code F-05.
the pump is blocked
Posted on Mar 30, 2010
How can I find out the age of my washing machine
where did you buy it from they may have records on your purchases and could advise you on the purchase date.
Feb 24, 2015 | Indesit IWC6105 1000 Spin 6kg Load Washing...
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
Is there a filter on a indesit wdg1095w
The lint filters on washing machines over the past 10+ years are mounted unter the tub. When the spin cycle starts, the water drains out of the tub, through the filter to clean it out/off, and out through the drain hose.
Apr 30, 2012 | Indesit Washing Machines
Washing machine won't drain
Sounds like the pump is not working, or the filter is blocked.
If there is a removable bottom front panel of washer, remove this and the filter should be located behind it. Remove and clean.
Please rate my solution.
Thanks.
Jul 18, 2009 | Indesit W 123 Front Load Washer
Hi i have an indesit wd12x washing machine that does not drain the water. How do i get to the filter to clean it? Thanks
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Washing machine problem
probably filter blocked. if memory serves me right, filter is located in pipe from sump to pump. remove bottom back panel. remove sump hose where ir is clamped to tub and filter is inside this pipe, take out and clean
Jun 18, 2008 | Indesit W 123 Front Load Washer
Samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Feb 13, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
1,344 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
