Gigatybe MB. Ran for 3 months without problems. Lately it reboots or total shuts off. Sometimes it restarts if I cycle the power sometime it simply ignores me. Come back a few hours, it starts without a problem. A few hours later or a few days later, it shuts off again. Replaced power supply, same thing. Any ideas?
Let's guess it is a Maytag Dryer :>/
'Make model (what it is) in all questions please.
A PF (Power Failure) error code indicates that the drying cycle has been interrupted by a power failure. Touch and hold START to restart the dryer cycle or press POWER to clear the display.
Dec 14, 2019
First make sure your fan is operating on your processor it takes about 3 mins for it to over heat and stop and shut itself down for safety to prevent burning up the processor.if its not this read on. Also when you boot into safe mode then do a system restore to a date before the problem started. But first in safe mode run your antivirus scan to find something that is missed while being hid behind the operating system while functioning. Remember to rate my solution and leave testimonial this is how i earn my achievements here on FixYa thanks in advance
How many years do you own that desktop computer? You have a problem with your Ram: Transcend: 2GB 1333 Mhz
Ram is always responsible to boot and run all system required by your computer A defect ram cannot boot or not properly run application e.g. Power-On-Self-Test (start up of your computer) Booting your Operating System Running your Application like Microsoft office , Photoshop and so on
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
