Question about E-Machines eMachines Desktop PC
Wireless router cannot find internet
I am trying to instal a Netgear router and I am not able to get the router to find an internet connection. I cycled the cable modem and computer before trying the instalation, this did not help. I am wondering how much I can increase the memory in this model computer?
  • 837 Answers
Well the memory issue and the inabilty to "net" connect are not "connected" to each other.
In order to answer the memory question I need your exact model #
As for the internet .. be sure your are connected first properly at the cable modem. Then from the modem to the router you should have a CAT5 cable. Then from the router to a PC so that you can configure the router and setup the wireless properties
Posted on Dec 31, 2008
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
Jan 18, 2013 | NetGear MBRN3000 3G /4G Mobile Broadband...
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Hi I have installed a netgear wireless usb adapter wg111v3 onto a PC (on another PC i have a netgear DG834GT router). After installing the adapter the "signal strength" is EXCELLENT and the "status" is...
You might not be getting a correct ip from your wireless router.
first, try to power down the computer and your netgear router for about a minute or two. turn the router on first. once the lights are stable on the router, boot up your computer. if your still not able to access the internet. try this
go to start > control panel > network and internet > network connections or network and sharing center > right click on wireless network connection and go to properties > highlight "internet protocol version 4 (TCP/IPv4)" > left click on properties, the wireless network connnection properties will then be opened.
make sure that the radio buttons are on "obtain an ip address automaticaly" & "obtain DNS server address automaticaly".
Sep 17, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Netgear installation
have a look at this site it will help you http://www.lycoming.edu/acad/Netgear%20Wireless%20Router%20Setup.htm
Sep 17, 2007 | NetGear WGT624 Wireless Router
E-Machines eMachines Desktop PC Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
