Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
KEYPAD STICKING AND STOPS WORKING
MODEL:KCMS1555RWH
KEYPAD BUTTONS NEED TO BE PRESSED REPEATLY TO OPERATE. THE PROBLEM SEEMS TO BE GETTING WORSE...NOT BETTER.
    President:
  • 2,692 Answers
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Posted on Dec 31, 2008
How do you remove the child lock?
It sounds like your membrane keypad may be shorted.
If you'll contact me with the full model number from your tag, I'll give you all the information you would need. In many cases, this is a do-it-yourself repair.
http://www.microwavecontrol.com
Oct 08, 2016 | Sharp R-303Cw Microwave Ovens
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
I've had mine for approx. 5 years and this year the buttons started to not work. I could only use the One Minute Plus button. This morning nothing worked! I unplugged it, replugged it and still nothing....
On these models, each of the four plastic buttons on the right side of the control panel runs a hidden pad on the membrane keypad.
The other pads on the keypad are fully exposed once you open the door and you just press them directly to operate them.
These plastic button assemblies have been upgraded due to weakness and breakage.
Most often it's the bottom two buttons (Stop/Clear and Start/Minute Plus) that fail.
You can order the button assemblies here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The service manuals you need to refer to are here and here.
Oct 01, 2010 | Sharp R-1502 Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
I cannot press start and stop button i think sensor is not working i can press rest 1234567 button n not 890 n start n stop button
Normally, it suggests the keypad is faulty. The fact that you have part function indicates the board is functioning. Replace keypad.
May 28, 2010 | Sanyo Microwave Ovens
The start and stop pad just stopped working ,to turn it on i have to press the extra min button and then I get extra min and it starts working.
You have a failing membrane keypad.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and mention that you have a failed keypad.
Nov 28, 2009 | Frigidaire Mid-Size Microwave
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
My Touch pad does not work, can someone help? kenmore mocrowave model 721.62624200 microwave buttons work sporatically. if i push in a downward motion they work sometimes microwave blew a fuse a couple of...
It sounds like the keypad is worn out. The fact that you can get them to work sometimes by what direction you push on them, tells me that the contacts are not working correctly.
Did you have this problem prior to the fuse blowing or did it start after you replaced the fuse?
I don't believe the fuse blowing is related to the keypad problem. I also don't believe that you have a microprocessor problem because you say that the function buttons work but the number keys don't work right. If the microprocessor was faulty, it would not be able to read any of the keys.
The fact that the number keys are not working doesn't surprise me. When you go to cook something, you will press the number keys several times, while only pressing start or stop once. This is why your number keys have worn out first. These keys have a limited number of cycles (presses) and it sounds like its time for a new keypad.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Microwave Ovens
Button seems to be stuck
Some people spray some quimico to clean the microwave then on keypad don't have to spray ane liquid. To clean the keypad have to use paper with little water. I think your problem is keypad water damged, if I right you have to replaceit.
Aug 23, 2007 | LG LMVM1935 Convection/Microwave Oven
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
179 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
