Question about Panasonic (CF61-TPAD) for Toughbook CF-61 (CF61TPAD)
Panasonic cf-61 how do u get into the bios settings at start up
Ive tryed ctrl alt delet ctrl alt esc after it cks the memory next screen i have 2 push f1 to go on how do i fix this????
    New Friend:
Reset the computer
Posted on Jan 10, 2014
2 Suggested Answers
SOURCE: panasonic laptop cf-61
I found these links below they should be of some help... tech.yahoo.com/gd/setting-up-your-laptop/153197 mobileoffice.about.com/od/laptopstabletpcs/ gr/bkrwlaptops.htm
Posted on Sep 04, 2007
How do I get past theYour pc will restart in 2 days to finish installing important updatesIt won't let me enter my password to unlock the pc
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order
If this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jun 23, 2013 | Acer Computers & Internet
The boot order was saved in the bios and now when i press f2 it wont let me in
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
Apr 17, 2013 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Feb 05, 2013 | Dell Latitude D800 Notebook
CD Drive will not allow boot
Change the boot order
Feb 03, 2013 | Computers & Internet
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
Can't setting bios
The BIOS information is typically found at or near the top of the POST screen
ALR PC non / PCI = CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
during the boot process you will see on the screen to press a certain key usually delete or F2 to enter setup
this will differ depending on which bios you have
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
hope this helps
Apr 08, 2012 | Computers & Internet
Press delete enter to set up so what can i do nothing is working
Sound you are trying to get into the BIOS, some use key F2,F8, or F10, it will say very fast what the correct key is, it might be very fast.
The first item is the key or key combination. The second is the model of PC or the maker of the BIOS. You'll see some companies listed many times, with different keystrokes. That's normal. (It's not that manufacturers can't make up their minds. It's just that they change suppliers and use different BIOS setups.)
Delete: AMI or Award BIOS.
Esc: Toshiba
F1: Toshiba; Phoenix; some IBM PS/1 models.
F10: Compaq.
F2: NEC.
Insert: IBM PS/2.
Tab: eMachines.
Reset button (press twice): Some old Dells.
Ctrl-Alt-+: Various computers.
Ctrl-Alt-?: Some old IBM PS/2 models.
Ctrl-Alt-Enter: Some Dells, others.
Ctrl-Alt-Esc: AST, Tandon, others.
Ctrl-Alt-Ins: Zenith PCs, Phoenix BIOS.
Ctrl-Alt-S: Phoenix BIOS.
Ctrl-Alt-Shift with Del (on number pad): Olivetti.
Ctrl-Esc: Many PCs.
Ctrl-Ins: Some IBM PS/2s.
Ctrl-S: Phoenix BIOS.
Ctrl-Shift-Esc: Tandon
Dec 02, 2009 | Acer Aspireā„¢ T180 PC Desktop
How to get into bios
Restart the computer and press F2 right away.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
ALR PC: (F2) or Ctrl+Alt+Esc
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
E-Machine T1100
What kind of BIOS version do you have?? here are some commands for the diverse kind of BIOS.
AMI (American Megatrends, Inc.) BIOS: DEL
Award™ BIOS: CTRL+ALT+ESC
Award BIOS: DEL
DTK® (Datatech Enterprises Co.) BIOS:P ESC
Phoenix™ BIOS: CTRL+ALT+ESC
Phoenix BIOS: CTRL+ALT+S
Phoenix BIOS: CTRL+ALT+INS
Feb 15, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
123 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
