Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Which pipe is my inlet, and which is my outlet?
I want to back fluch from my pump to my skimmer. I have the XP2e pump. My pipes go into my insulation foam, prohibiting me from following it back to the motor. I want to back flush from the inlet at the motor, but don't know which is the inlet, and which is the outlet? Any help?
  • Nick W Jan 05, 2009
    I called the Manufacturer once during business hours. The best description is that the suction inlet is horizontal, and at the front. the discharge is verticle or upright. I then found my clogged pipe, cleared it and have been enjoying the hot tub again. Thanks.
    Problem Solver:
  • 11 Answers
The inlet is at the front of the pump, and it discharges from the top.
Posted on Jan 03, 2009
How do i prime this swimming pool pump?
The normal procedure would be to unscrew the top of the inlet basket and fill that with water until it flow out down the inlet pipe, then replace the top cover. Make sure the skimmer box basket is clean, the pool water level is high, or put a fast running hose in the skimmer box to make sure the primed pump does not have to pull the water up from too low at the inlet.
If it will not pull the pool water in when started, then -
- there is a leak or blockage somewhere on the inlet side
- the pump impeller is damaged
- the filter is clogged too much and causing back pressure
- the pump power and pipe sizing are mismatched
Oct 08, 2014 | Pool & Spa
Won't drain completely
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe and that the pump is actually operating. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jul 09, 2011 | Kenmore Dishwashers
Final rinse water not drained out of the drum
May 09, 2011 | Washing Machines
Washing machine wiill wash and spin but water doesnt pump iout
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe and that the pump is actually operating. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine again before using it again.
May 05, 2011 | Washing Machines
Dishwasher does not drain
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe and that the pump is actually operating. Check the selector valve inlet to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine again before using it again.
May 03, 2011 | Electrolux Dishwashers
My washing machine does not drain water after washing
Apr 11, 2011 | Bosch Washing Machines
Where can I buy a Flowmaster XP2E 2hp pump, Model No. 05250000-6?
They no longer sell that particular model pump. The closest comparison is the new XP2E 2 HP pump which comes with the 2" inlet and outlet, but everything else is the same. It also comes with the fittings to convert from 1.5: to 2". This unit goes for about $450 on line. I also have this in stock and would sell it for the same price. Brand new in the box.
Contact me @ ahudson43@yahoo.com if interested
Feb 25, 2011 | Aqua Flo 2 HP Aqua-Flo Pump: 1.5" in/out,...
Which tube takes water from pool to pump and which tube puts water back in on the model 633
The outlet from the skimmer goes to the pump inlet (center) the pump outlet goes to the filter inlet. The filter inlet goes to the return to the pool.
Jul 03, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Received this sand pump. However there were no instructions on how to put it together. Shows it already together but it was sent apart in two boxes! HELP
They're all about the same. Skimmer outlet goes to pump inlet. Pump outlet goes to filter inlet. Filter outlet returns back to the pool. You will have to fill it with sand. Look at link: http://www.propools.com/instructions_index.php Most any of these instructions will work. Pay attention on how to add sand so you don't break the "spider" piping in bottom of filter. I usually have water in first to absorb the shock of adding sand. Don't let sand enter the stand pipe in center of filter. Cover with plastic cup or something.
Jun 30, 2010 | Sta Rite 21" Sand Filter 15HP Pump
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
119 people viewed this question
Top Aqua Flo Pool & Spa Experts
Bill Jordan
Jay Finke
Jay Finke
Gene Haynes
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
