Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Looks 3d
By uhlirmelissa on Dec 31, 2008
are 55 inch looks like 3d the colors don't seem to come together
Same Problem
Jan 07, 2009
-   the remote wote let me reset the convergence -   uhlir
Solution #1
posted on Dec 31, 2008
Not Rated)
danaw007
Rank: Apprentice
Rating: 75%, 1 votes
sounds like you moved or bumped the tv. the convergence probably needs to be reset. either through the menu on the front or on the remote you need toget to the set-up/convergence screen and line up the crosshairs to reset.
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
when in cable mode, my samsung hlr4667wax hdtv has vertical green/red lines. the lines do not... (More)
Answer
I have connected other dvd players through scart leads without problem, and works well with my Sky+... (More)
Answer
My PT-47WXC43 power light is flashes 5 times and TV will not turn on. Any ideas?
Answer
Tv works OK, but the problem is the picture is starting to get greenish, yellowish colored
Answer
the problem im having is the picture will get bright then dark and then normal picture.it's random... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
