Question about Microsoft Office XP Professional OEM w/ Publisher 2002 Bundle (M04-00245OEM) for PC
Cannot show hidden text in Word
I hid several paragraphs. Now I want to show them. Word instructions say use the Show/Hide button on the standard toolbar. There is only a "Show" button, which does not provide for undoing a hidden paragraph. No help under "Format," either. No useful buttons among those not already present. Using M'soft Office XP Professional 2002. This particular version was, I am told, made especially for Dell. I am using HP. ??? The only other problem I have met is that the keyboard cannot be shifted to Spanish language.
    Novelist:
  • 151 Answers
Select the text you want to hide. On the Format menu, click Font, and then click the Font tab.
Select the Hidden check box(under Effects) .
Note To view hidden text on the screen, click Show/Hide on the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.).
In order to display Standard toolbar:
 On the Tools menu, click Customize.
Click the Options tab.
Under Personalized Menus and Toolbars, select the Show Standard and Formatting toolbars on two rows check box.
under the file, edit, menu, insert format you will see the standard toolbar at the exterme right just beside Read, ?, box showing in percentage(100%) you will find and symbol just place the mouse cursor on it will show "show/hide".
Q) The only other problem I have met is that the keyboard cannot be shifted to Spanish language.
A)In Microsoft Windows XP 2002 , on the Windows Start menu, point to All Programs, point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office 2003 Language Settings.
I
Click the Enabled Languages tab.
In the Choose the language that defines default behavior in Microsoft Office applications box, select the language you want, and then click OK.
A message appears describing the effects of the change. To continue, click Continue and lose customizations
 now when you enter in word document click Tools----->Click Language---->Language settings and select the language and click default and then continue....
Thank you
M. Sridhar
Posted on Dec 31, 2008
How do I get a file back that was hide?
Main Menu > Media > (highlight pictures) > press Blackberry button > Explore > Media Card > Blackberry > pictures > press Blackberry button > show hidden
In short, navigate to the folder where you hid the folder/file and press the Blackberry button and choose show hidden. you'll then see the hidden item in the list as a semi-transparent item. Highlight the item > press the Blackberry button > Properties > uncheck "Hidden". You can then go back and access the file as you normally would.
OR if you have a PC, use windows explorer & go to the Media Card folder where you hid the folder, in the Tools Menu- Folder Options- View tab- select "show hidden files and folders".
You folder will be visible (in windows) but slightly transparent.
Right-click the folder, select Properties.. uncheck the 'hidden' checkbox and click 'Apply'
OR
Nov 04, 2014 | RIM BlackBerry Curve 3G 9300 Cell Phone
Tip
BlackBerry Tour: How to hide or show programs
You may have several applications on your BlackBerry that you don't use very often. But you don't want to delete them, because one day you might decide you want them. The easy solution is to hide them, so you don't see them during regular use, but they're there if you ever need them.
To hide a program, highlight it with the trackball and click the BlackBerry button (the one that looks like a paw print). Then just select Hide from the menu, and that program will disappear from view.
If you later decide you want it back, click the BlackBerry button anywhere in the Home folder (or whichever folder that application was located in) and choose Show All from the menu. Hidden programs will show up, but they will look fainter than the other programs, as if they were faded or washed-out.
You can leave your BlackBerry set to Show All to see the hidden program, or you can "unhide" it so it's always visible. To do that, highlight the program and click the BlackBerry button, then select Hide again to remove the check mark. The program will be visible again.
Once you've made the program visible again, you can either uncheck Show All or leave it checked. Show All can not be applied to some folders and not others; if you select Show All in the Games folder, for example, hidden applications in all folders (including Home) will be visible.
The same procedure works for folders as well as applications, and it also will work for applications or subfolders that are located in another folder beside the Home folder.
on Jun 22, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Typing in ms.word shows black spot with text
It doesn't print them right? There is show paragraph option. It shows spaces as dots, and a musical looking p for paragraph breaks. Look under view.
Nov 23, 2012 | Computers & Internet
Printing jobs are coming out with the text off the page
Some blank paragraphs may have spilled onto the last page. To view paragraph marks (paragraph mark: The nonprinting symbol that Microsoft Word inserts when you press ENTER to end a paragraph. The paragraph mark stores the formatting you apply to the paragraph.), click Show/Hide on the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.). If you see paragraph marks without text on the last page of your document, delete them. Then click Print Preview on the Standard toolbar to view the document as it will be printed and verify that there is no longer a blank page at the end of your document
Sep 26, 2011 | HP OfficeJet Pro K8600 Printer
My C drive shows 29 GB full but when I check my folders it only adds up to 7 GB! Can you help to find the rest?
open command prompt
type the code exactly as written
cd/ (press enter)
dir /a:h (press enter)
If it shows two files like hiberfil.sys and/or pagefil.sys do lemme know
There is nothing to worry it happens some times. I will give you the cure if the same.
rate if you like
Feb 15, 2011 | Microsoft Windows Vista Business with...
Can't find hidden media folders
Follow these steps to hide or show pictures on the BlackBerry smartphone:
  1. On the Home screen of the BlackBerry smartphone, click Media.
  2. Go to Pictures.
  3. Open the picture that you want to hide.
  4. Press the Menu key and click Properties.
  5. Select the Hidden check box and click Close.
Follow these steps to show a picture on the BlackBerry smartphone:
  1. Click Media.
  2. Press the Menu key and click Explore.
If the picture is in Device Memory,
  1. Click Device Memory.
  2. Press the Menu key and click Show Hidden.
If the picture is in Media Card,
  1. Click Media Card.
  2. Click BlackBerry.
  3. Press the Menu key and click Show hidden.
Additional Information If the computer is set to Show all hidden files and folders, the BlackBerry smartphone user should be able to view all hidden pictures by using Roxio® Media Manager. However, pictures cannot be hidden or shown using Roxio Media Manager. If a picture is on a media card and the computer is set to Show all files and folders, pictures can be viewed, hidden and shown by using the removable disk drive.
Sep 12, 2009 | RIM BlackBerry Pearl 8100
The virus has hid my files on my xd card, virus is hidden too
Are you sure it's a virus? maybe it's gist the option Hide/show system/hidden files.
if it's a virus, put the xd card into the reader, than use a hack program to get the data out. make sure you scan it with an antivirus program before getting it copied onto the hdd.
Jan 11, 2009 | Computers & Internet
In Word, I cannot show text that I hid.
If you press the Show button down, it will show all text; if you press it again, it will hide your hidden text. To hide text, click on Format>Font and click the Hidden checkbox. If these do not work, your best bet is to reinstall Word; a file may have gotten corrupted.
Dec 31, 2008 | Microsoft Office XP Professional OEM w/...
Microsoft Office XP Professional OEM w/ Publisher 2002 Bundle (M04-00245OEM) for PC Logo
254 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
