Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag dryer mdg508daww
No heat did replace igniter does start cold gets hot not for long cool down its starts heat only for short time
  • 76 Answers
Sounds like you need to replace the coils on the gas valve. there are 2 of them, they are rond and black
Posted on Dec 31, 2008
No Gas Flame
Very common problem. The solenoids when cold will sometime work once then get hot and fail. Replace the coils. I made a short video which shows how it works and how to replace the coils on a similar dryer with the same type of solenoids:
Aug 29, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer MDET446AYW shuts off after a minute or so
Does it come back on right away when you start it again? or do you have to wait. If it starts, stops, starts, excetera..if so you will need to replace the control board. Part Number: AP4046791 made by WHIRLPOOL. Now it is not a cheap part, but most have a 30 day moneyback. The slight chance of a broken element shorting, causing the thermistor to over heat, cool down and run for a short time. is also a possible issue. But for the Maytags I have worked on in this model, most of the time it has been the control board. I am hoping it is the element issue for finace purposes. It is a good dryer unit, I own one. : )
Dec 29, 2011 | Maytag Dryers
I have a Maytag Gas Dryer Model# MDG508DAWW. It comes on and tumbles but won't heat up. I bumped the back of it with my hand and it came on and got hot then a few minutes later it started getting cold...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Oct 06, 2010 | Dryers
Dryer doesn't get hot. It will ignite, get warm then goes cold
I would suspect the valve coils. they will work for a short time and then fail, cool off and work again. very easy to replace.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Dryer too hot...no cool down
no the thermal fuse has nothing to do with that,although it will open again if too hot and that may be why it opened in the first place.most high heat ,long dry times are the house ducting.try this experiment.remove your dryer from the house ducting and dry a load[it wont hurt a thing]if not as hot,then get that ducting cleaned.if still hot then make sure the inner dryer air ways are clean.your blower is spinning fine[not broken on the shaft]and also check with ohm meter,or visually that your heating element is not shorted to ground[then it by passes the cycling thermostat.if all those things good and still getting high heat i may replace the cycling thermo.but as a repairman i did not have to do that very often.most of the time it was the other possibles. i hope this helps abit God bless ,tom
Feb 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
564 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
