Question about Kenmore 24032\24036 Top Load Washer
I have a 110 series washer.Why can't I get hot water?
Hot water line is OK. I can only wash with cold water.
  • arniebraun Dec 31, 2008
    I have hot water to the valve. Screen is open. I think it must either be the valve or the temp control. Any ideas?
  • 153 Answers
Inside of where the hot water hose screws on there is a screen to catch debri. Yours may be completely clogged. Turn off hot water , unscrew hose and inspect screen.
Posted on Dec 31, 2008
  • samson-1
    samson-1 Jan 06, 2009
    If my comment was not appropriate why did you check your screen??
  • 76 Answers
I would like to help, but need more info please, is your hotwater turned on at the washer? if so, then i would look at 2 things.the first is the water fill valve, it sometimes becomes clogged at the screen. Take your hoses off at the washer and look into the valve to see if the screen is clogged, or the valve may just be bad and need replaced
Unit will not switch from hot to cold
check hoses connections- hot to hot and cold to cold at both ends. If not ok, check if you are setting the machine correctly. These days washing in cold water is effective.
Dec 08, 2013 | LG WM2101H Front Load Washer
Mixed Water Fill Causes Issues with Water Pressure
You will have to be specific about what problem the pump is having. It seems to pump ok for everything else. Could the hot solenoid be shorting and sending electricity down the water to bother the pump? Solenoids are not real expensive, try a new one.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
Kenmore Top Loading washer gets very little cold water
You could try reversing the water lines and see when you select hot if cold comes out strong. If it does not then it should be the valve. If it comes out good in reverse, it could be the tempature sensor. Here is the link to parts and diagrams.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11023032100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00003&componentDescription=REAR%20PANEL&documentId=P0110152&backToLink=Return%20to%20Sub%20Components%20list
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washer produces Hot Water Only
first be sure you are getting a good flow of cold as far as the washer connection..if so ck inside washer connection for a small wire screen be sure it's not plugged if so clean and flish line to remove anything inside hose ..be sure to put screen back in ..if still no cold suspect bad cold section of valve..replace valve..last remote possibility temp switch is bad
Sep 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
