Question about Navigon 2100 Portable GPS Receiver
NAVIGON 2100 won't move as I go down the road.
NAVIGON isn't moving when I drive down the road.
The town of Lakeview only has 1 zip code and Navigon is showing 5 or 6 zip codes.
Thank you
Gary Boop
937-935-9547 Cell
Garyboop1 Try just rubbing you finger accross the screen, it should give you some result. Rusty1
Posted on Dec 31, 2008
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
My Navigon 2100 GPS lights like it's charging, but it won't turn on
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
Jun 30, 2011 | Navigon 2100 Max Portable GPS System
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Want to install xcsoar on a navigon 4310 pna. put the xcsoar program on a micro sd card, can't get it to work.
Hi Mart136,
Were you able to get XCSoar to work on your Navigon 4310? I have the same problem with XCSoar and my Navigon 2100 Max. I did exactly as prescribed for installation on the XCSoar site but my 2100 Max keeps asking for the Navigon SD card .. it doesn't want to recognize a standard SD card.
Does anybody have any suggestions? Thx Much!
Oct 04, 2009 | Navigon 2100 Max Portable GPS System
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Need users manual for navigon 2100
we purchased a used navigon 2100 it did not have a user manual with it and we would like to have one
Feb 20, 2009 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Screen stuck
Had same problem with a navigon 2100 and after trying my daughters car charger it worked properly. Called Navigon and they are sending me a new car charger.
Nov 27, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 text to speech not working
the same happened to my 2100 3.5 inch. any remediatons?
Nov 14, 2008 | Navigon 2100 Max Portable GPS System
Will not turn on
1) hold down the reset button until the light the led light comes
Sep 16, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 Portable GPS Receiver Logo
176 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
