Question about Magic Chef 31000 Gas Kitchen Range
Oven goes in lock mode.
I have amagic chef range (gas range). are eletric went off on sunday and when it went back on we tryed to reset are oven and it goes in lock any time we puy it on bake and it goes back i lock mode. Please help.........
  • 76 Answers
Unfortunately it sounds like you need a new board
Posted on Dec 31, 2008
  • Beth Davis Dunn Dec 20, 2014
    mine did that to shows locked the oven door is not locked
Hello, I have an older model magic chef gas stove/oven. It has a self cleaning oven option that I tried using. It didn't work, but now the lock light on the stove is still lit up as if it's still in...
most likely your latch assembly on unit has failed.... try resetting breaker to unit and make sure latch is not half opened or half closed while breaker is off... after checking reset breaker and see if this helps if not then probley going to need a new latch assembly and or possibly the control on unit... self clean on all ranges and ovens are trouble in my opinion they get entirely to hot and usually are ran to long... i know you said yours didn't work leads me to believe there may have already been damage to one of the pcb relays on the control but try the above first and you may luck out.... good luck to you
Jan 13, 2011 | Magic Chef Ovens
I have amagic chef gas appliance serial #3x 886115 model#7211w-5bw. can the top half be removed so that the bottom still functions???
No...while there are two ovens... the frame and most of the controls are common...so that you cannot eliminate one and still have the other work...
technically it may be possible but the cost would be more then a new oven...
heatman101
Jan 11, 2011 | Magic Chef 9112 Gas Double Oven
Magic chef model# cer3725acw. Using stove top burner.(CAL) Error message came on briefly on touch pad display window. Can't change time on clock,turn on oven,set temp.or timer.Burners work fine. Unplugged...
It sounds like a bad control. Before replacing the control, make sure it is not in Sabbath Mode, Child lock and if all else fails try resetting the control to factory defaults. If none of these work then replace the clock/control part number 5701M827-60. This part runs about $175.00
I attached a cut out of the service manual, to show how to reset the locks and factory defaults
May 27, 2010 | Magic Chef Kitchen Ranges
Magic Chef gas range oven not working after cleaning
You controller is your likely culprit. There is a relay on it that controls the oven. When it first wouldn't go off, the contacts in the relay stuck together. When you unplugged it you may have had to pull it out from the wall, which may have broke the connection. It works by way of a small electromagnetic coil that brings the contacts in and out. If that coil breaks it will look like it is on, but won't have any power to the oven coils. These controllers are easy to replace, but expensive. $75 to $300 depending on what you need for your unit.
Jan 04, 2010 | Kitchen Ranges
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven goes on without being turned on
the control switch tripper problem that switch has to be replaced with a tripper.
Dec 15, 2008 | Magic Chef 31000 Gas Kitchen Range
hi there,
yes, you can reset the valve. it's as simple as turning the lever on and off. just like a furnace.
Nov 12, 2008 | Kitchen Ranges
I have a 1948 Magic chef gas oven.Model # 8620. The gas was turned off at my home and the pilot light on the oven went out. The gas is now on and I need to relight the pilot light. I am not sure on the ove...
You did say 1948, as in 60 year old range?
Well, gas ranges did not have fancy safety valves or things like that back then. Most likely when you turn on the gas, a small amount of gas begins escaping at the pilot orifice. Then use a long handled lighter to put a flame there. Pilot should light right away.
Oct 11, 2008 | Magic Chef Kitchen Ranges
Magic Chef super capacity range.
oven takes to long to heat, broiler works fine, even the clock works it's just not heating fast....the bottom lights up,but not the top?
Nov 07, 2007 | Magic Chef 31100 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
168 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
