Question about Maytag HYE3658AY Electric Dryer
Loose Tumbler Fin In dryer
I have a tumbler fin (maytag front load) that has come loose on one end-how would I go about fixing-would I have to order a new fin. I cannot use it at this time-as I think the otherside would come off and or scratch up the inside of the dryer-? any help would be appreciated.
  • 318 Answers
Most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Posted on Dec 31, 2008
2 Suggested Answers
  • 8404 Answers
SOURCE: repair loose tumbler fin
Pop the top, remove the front, the drum will come free. Take pictures of how the belt goes around the motor. Fix your "fin" and reverse.
The top is held down by spring clips.
Thanks for your interest in FixYa.com
a
Posted on Dec 12, 2009
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Loose fin
there are two clips located between the front part in the frontpush those clips in and lift it up rest it back out of the way some of the dryers have small bolts holdind the fins on if so tighten them up and some dryers have only push in plasic clips these fins have to be replaced i certainly hope that i was able to help you and by the way close the lid, thank you.
Dec 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Repair loose tumbler fin
a
Dec 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Loose vane/fin on the Maytag LDE8406ACE
On almost all dryers the top will release by itself without requiring you to remove the front. There are two small clamp-like mechanisms under the top on the front side. They can be released easily by sticking a flat-tip screwdriver straight into them and pushing in. Once you open the top you can spin the drum by hand and tighten the screws on the fins. Take not however that some fins are only placed in by plastic snaps, and if it is loose it probably means that it is broken and will require repairs.
Dec 12, 2009 | Dryers
One of the "fins" inside the drum has become loose. It hasn't come off, it's just loose...how can I fix it? Thank you!!
hoping it is a neptune.........
remove the screws on the door hing to cabinet
and the two opposite
lift and remove the door
once the door is off
you can pull the front panel off
grab the thin sides and twist in and pull
onvce tat panal is off you will see two 5/16 screws on each side
remove those
you should be able to lift the top
once you do you should be able to see the top of the tumbler
turn till the loose fin is on top and just tighten the screws back out and your good to go
Oct 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer has three tumbler arms and one is loose. I can see set screws but do not know how to get to them.
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below (Should be similar to yours) to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Dryers
Maytag neptune model MDE5500AYW loose tumbler in drum
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose and broken baffle
d
Take off 4 door screws 2 right 2 left remove door pull front forward them two screws 5/16 in front with two brackets that hold top down. thats it just rotate drum and tighten or replace fin . ten minutes tops is all it takes.
my fin broke the screw holes so i will try longer screws if not i will leave off and run with two.
Mar 07, 2009 | Maytag MDE7600AY Electric Dryer
DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Jan 06, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
A tumbler fin
This isn't much help, but those fins will break off. I have had them break off. I am ordering some new ones, called "baffles" and will be installing them. I hope I can the top open on the machine.
Jun 16, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag HYE3658AY Electric Dryer Logo
339 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
