Question about Zyxel ZyAIR B-2000 Wireless Router
I am trying to secure my wireless network that utilizes the Zy Air 4 port V.2 router. How long do I have to push the default button to re-set the router, and what is the default password so that I can then re-configure my wireless with my own name and password?
  • 154 Answers
P/w is 1234, press reset button for 60 seconds -
Posted on Dec 31, 2008
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address (192.168.2.1) is not opening, even i have reset the router
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 09, 2012 | Belkin Computers & Internet
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Netgear 824, security = intermittent WiFi connectivity
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Jul 13, 2009 | NetGear RangeMax WPN824 Router
Portable devices recognize router but cannot connect
Try to change the wireless security to WPA-PSK(TKIP) or WEP.
From the above configuration, please try to connect your portable device to the wireless settings of your Netgear router.
May 07, 2009 | NetGear WGT624 Wireless Router
Don't know how to manually set security, ip address ect
5. Power cycle.
Apr 19, 2009 | NetGear WNR854T Router (WNR854T100NAS)
I have a NETGEAR Rangemax wireless router. Everything appears correct (power on, wireless blinking, internet connected). However, when I try to connect with a wireless laptop, they can "see" the network...
Do Firmware Upgrade
1. Please verify the model and version of the router underneath it.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and select the model of the router.
3. Please click on the appropriate version of the router.
4. Select the link of the latest firmware. Please click on the button Right-click and Save to Download.
5. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
6. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
7. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
8. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
9. Click on Maintenance and then Router Upgrade.
10. Click Browse and locate the upgrade file in your Desktop. Click Upload.
11. Please wait for the router to reboot.
12. Reset the router.
b. Unplug the power adapter for 10 seconds and then please plug it back in.
Configure the router;
5. Power cycle.
Apr 19, 2009 | NetGear RangeMax WPN824 Router
Resetting netgear rangemax wpn824
5. Power cycle.
Feb 08, 2009 | NetGear RangeMax WPN824 Wireless Router...
401 error while trying to access internet - any site
Note: Firewall, anti-spyware and pop-up blocker need to be disabled.
1. Please connect the computer directly to your router. Check the IP address.
a. Go to Start and then click Run.
b. Type cmd (Windows 2000 or XP) or command (Windows 98 or ME) then click on OK.
c. On the command prompt, please type "ipconfig/all" and then press Enter.
d. Look for the Default Gateway. This is the IP address of the router. Usually, it is a 192.168.1.1.
2. Check if we can communicate to the router.
c. On the command prompt, please type ping 192.168.1.1.
Note: In this example, we used 192.168.1.1 as the IP address of the router.
d. There should be replies from the Default Gateway address. Look for ping statistics and you should see a sent: 4 and receive: 4.
3. Optimize browser settings.
a. Please open Internet Explorer and click Tools.
b. Select Internet Options then click Connections.
c. Click on LAN Settings. Make sure that all boxes are clear and then click OK.
d. Click on General Tab. Click on Delete Files, Delete Cookies and Clear History buttons. Then click Apply.
e. Click on Security tab.
f. Click on Internet and Custom level icons.
g. Under the Settings list, scroll down and set the User Authentication to Automatic Login. Then please click on OK.
h. Go to Advance tab and click on Restore Defaults or Reset. Please click on OK.
4. Access the web-based utility of the router.
a. Open any web browser like Internet Explorer or Netscape Navigator.
c. For security reasons, the router has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
Note: If it does not take password as the password, you might have changed it when you have run the setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the NETGEAR Setup CD to reconfigure it.
If it still does not work, please try the following:
5. Reset the router.
6. Try other browsers like Internet Explorer, Mozilla Firefox, Netscape, etc.
If you still cannot access the routers page, try another computer and connect it on your router. Then repeat the steps.
5. Power cycle.
Jul 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Zyxel ZyAIR B-2000 Wireless Router Logo
244 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Justin
Justin
Courtney Lomax
Courtney Lomax
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
