Question about Kenmore 24032\24036 Top Load Washer
It doesnt recive the power
The washing machine doesnt want to recive the energy after 2 days of frozen cold weather
  • 135 Answers
Your water valve is probably frozen. Put a portable heater in the area overnight and see if that helps. you may have to thaw the pipes / hoses with a hair dryer - be careful!
Posted on Dec 31, 2008
Our Roper Top Loading Washing Machine won't fill with cold water and the machine makes a electrical buzzing noise when you turn it on set to Cold/Cold.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
Jan 20, 2016 | Roper Washing Machines
How to tell if fuel line is frozen starter turns but doesnt crank engine
in extremely cold weather, you may need an engine block heater or lighter weight oil. you can verify that the gas is flowing if you disconnect the main gas line to the injector/carberator, attempt crank, and see whether fuel squirts out or not. if its cold enough to freeze gasoline, it could be cold enough to freeze oil, anyway
Jan 09, 2014 | Depo Auto Parts Saturn L100 L200 LW200...
Model WPRB9220C draws cold water when it's supposed to draw hot.
Your hot water inlet solenoid has failed and needs replacing.
Mar 11, 2012 | GE WPRB9220C Top Load Washer
My car doesnt want to start up right away in the morning. Almost like its really cold out and it takes it a min. The rest of the day its fine runs great. Any ideas?
Reason 1 - Gasoline, like any other liquid, evaporates less when it is cold.You have seen this -- if you pour water onto a hot sidewalk it will evaporate a lot faster than it will from a cooler place like a shady sidewalk. When it gets really cold, gasoline evaporates slowly so it is harder to burn it (the gasoline must be vaporized to burn). Sometimes you will see people spray ether into their engines in cold weather to help them start -- ether evaporates better than gasoline in cold weather.
Reason 2 - Oil gets a lot thicker in cold weather. You probably know that cold pancake syrup or honey from the refrigator is a lot thicker than hot syrup or honey. Oil does the same thing. So when you try to start a cold engine, the engine has to push around the cold, gooey oil and that makes it harder for the engine to spin. In really cold places people must use synthetic motor oils because these oils stay liquid in cold temperatures.
Re ason 3 - Batteries have problems in cold weather, too. A battery is a can full of chemicals that produce electrons The chemical reactions inside of batteries take place more slowly when the battery is cold, so the battery produces fewer electrons. The starter motor therefore has less energy to work with when it tries to start the engine, and this causes the engine to crank slowly.
All three of these problems can make it impossible to start an engine in really cold weather. People either keep their cars in heated garages or use "block heaters" to get around these problems. A block heater is a little electric heater that you plug into the wall to keep the engine warm.
i hope it was convince answers
May 30, 2011 | Dodge Stratus Cars & Trucks
Just makes a noise when you turn on to any of the cycles. Washing machine is in garage, therefore could this have been affected by the cold weather we have experience over the last few weeks?
It could well be that the water is still frozen in the inlet pipe/s, you will have to wait until it warms up a bit more.
The noise you can hear is probably the inlet valve/s energising, but unable to let the water in.
Dec 29, 2010 | Washing Machines
It will not fill with cold water. Could it be due to the cold weather - the cold water pipe frozen. Kitchen is very cold (pipe is next to an east facing wall). Same pipe also fills the dishwasher,...
If youve taken the fill hose off and checked for running water out of tap and its not coming through, your machine is ok, you have a water fault.the humming is the water valve working.
Dec 21, 2010 | Washing Machines
My "security" Light came on while I was driving to
Sounds like you take pride in caring for your Buick:) You are probably correct about the cold weather affecting your "Security Light"...have you had your car washed recently? Any of the door trunk or hood jams could be frozen...and sending a "Security Alert"...I would monitor it over the next few days...hopefully some warm up...before having it serviced:)
Dec 08, 2010 | 2003 Buick Century
Why does it take over 2 hours to wash a normal load, is there a manual for this machine
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I don’t know what machine you have but the newer energy efficient machines do take far longer to complete a wash because they are basically cold fill. Part of the wash cycle is incorporated in the heating stage. Companies are all striving for the prestigious ‘A’ rating on Energy, Wash and spin, but in doing so have to increase the wash time. Sounds wrong it’s how it works! If you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Washing Machines
Fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Dwf-6010ap
I HAVE DAEWOO WASHING MACHINE MODEL DWF-6010AP
THE PROBLEM IS THAT COLD INLET IS LEAKING WHEN RUNNING I NEEDS SOLUTION OR WHERE CAN I GET PARTS
Jun 25, 2008 | Daewoo Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
