Question about HP Compaq Presario V2000 Notebook
Our v2000 takes several attempts to turn on - once on works fine
The laptop starts to boot when I press the power button but it doesn't "catch". After several attempts it will finally start up and from that point it works just fine. Is this a hard drive problem?
    Problem Solver:
  • 8 Answers
This could be a hard drive problem. Try taking the hard drive out and putting it in another laptop. Also try taking the battery out and then connect it only with the power cord connected. If you have the same problem it is most likely a hard drive problem. I would recommend that you back up the data and get a new hard drive.
Posted on Dec 31, 2008
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Computer doesn't reboot after turning off.
You could have a power supply problem. Start up is ******* a ps until it is fully up an running. You may have bulged caps in the power so that takes awhile to full charge up. I would start there. No other reason for it to do that because it runs fine after it gets started.
Jul 21, 2017 | Computers & Internet
Windows will not start on my laptop
2 choices turn the comp over un plug the battery leave about 2 minits.
then plug back in and try again .
If that doesn't work then when it starts 2 boot up press F8 several times it will ask normal start or select last known good configuration & select it . if that doesn't work have u aback up disk insert the 4 th disk and boot from that insert tha disck turn off comp and re start it will come up boot from disc press any key yes thats shold b it
Oct 02, 2012 | Sony VAIO Computers & Internet
Computer will not start up.
One thing that might be worth trying that I have seen work on several occasions is to disconnect the power, then remove the laptop battery, reconnect the power lead and try operating the laptop with no battery.
If this does work, then the laptop battery has probably failed and made a short-circuit internally which would be why it will no longer charge and why the laptop will not power on as a safety precaution.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
Dell inspiron m5030 wont boot up, ac adapter has green light then once it is pluged in light goes out.
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for forty seconds.
Install the battery and ac adapter .Now press the power button to attempt a boot into the OS.
If that doesn't work then remove the hard disk to see if it gets past the splash screen and the BIOS whines that it can't find a boo-table OS. That would indicate a hard disk failure.
Also try to remove the memory module(s) from the DIMM slots and then reinstalling them. That reset the modules and cleans some oxidation off the module pins (if there is any)
Hope this helps.
Let me know if you need more information
Thanks
Apr 26, 2011 | Dell Inspiron M5030 Laptop
Compaq Presario V2000 will not boot.
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Toshiba M45-S165 startup issues
This is normally a motherboard issue. I had one with the same symptoms and I had to replace the motherboard. Worked great after the board was replaced. I had to replace the board because unlike your issue mine stopped working all together. It did take a while before it quit though. Just a note: I have had to replace several of these motherboards for customers as well. If your LCD is broken, you may be better off to save your data and put it in a new laptop that would include a warranty unless your super fond of the machine or you have access to inexpensive parts.
Hope this helps...
Jan 30, 2009 | Toshiba Satellite M45-S165 Notebook
Laptop will not start up at all
When the computer starts up press the F8 button that will get you in Safe Mode.
Don't forget to rate this solution before you log off
Jan 26, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presaro V2000 will not power on after mini-pci card removed
HELLO,PRESS AND HOLD THE POWER ON BUTTON FOR A FEW SECONDS UNTIL YOU GET A POWER LIGHT.ONCE YOU GET THE LIGHT,THE LAPTOP SHOULD BOOT UP NORMALLY.IF THAT DOESNT WORK,REMOVE THE BATTERY AND TRY TO POWER UP WITH JUST THE AC ADAPTER PLUGGED IN.ONCE YOU GET BOOTED,INSTALL THE BROADCOM WIRELESS CARD SOFTWARE FIRST FROM THE CD THAT CAME WITH THE ADAPTER.THE SET-UP WILL THEN ASK YOU TO INSTALL THE CARD AFTER THE DRIVERS HAVE BEEN LOADED.YOU SHOULD BE ABLE TO GET ONLINE ONCE ALL THE STEPS HAVE BEEN COMPLETED.GOOD LUCK
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
