Question about Sony Cyber-shot DSC-W55 Digital Camera
I dropped the camera on a carpet floor lightly
Dropped camera
  • 2 more comments
  • lexiuc Dec 31, 2008
    I dropped the camera the floor and the camera will not turn on nor the lens open.
  • tryod Jan 02, 2009
    Same problem!  The lens will extend slightly and then retract.  It does this until a message appears saying to turn power off and on.  When this is done same situation again
  • MEYE123 Jan 03, 2009
    WHEN i TURN THE CAMERA ON IT BEEPS AND THEN SAYS TO TURN THE CAMERA OFF.
    IT KEEPS DOING THIS
  • jeclement Jan 05, 2009
    Dropped the camera on dorm floor. Camera still takes pictures if transferred from memory stick. View screen a bit of a mess - showing nothing. Probably actually cracked/broken in th fall. Is there a way to replace the view screen?
    JE Clement jeclement@msn.com
  • 122 Answers
Need more info you dropped and what ? does it work What?
Posted on Dec 31, 2008
Dropped camera shutter doesn't work but video does
Did you remove the battery and replace it after a few moments? this will "reboot" the camera, like a cold boot from a computer. Then try again. I can't believe a landing on the carpet would cause mechanical problems, but you never know.
Could be just a setting, and that will be restored after the boot.
Aug 27, 2014 | Olympus Cameras
Cannot load a tape into camcorder. I have tried two separate tapes, neitehr of them load in to the camcorder. A message comes up: "remove the cassette" when it has not even been loaded properly.
I had the same problem. Checked the site and found a solution of dropping the camera onto a carpeted floor from about 1/2m to 1m. Thought that it was bullsh1t but was desperate and so tried it. worked a treat!!!
Hope this helps.
Jul 14, 2009 | Canon DV-MV830i Mini DV Digital Camcorder
Camera won't turn on
Fixed! Several people I've described the problem to asked me if I dropped the camera, and I honestly did not remember dropping it, but I could've just forgot that it happened. Later, (after this was posted) it slipped out of my hand and fell to the carpeted floor. When I picked it up, I noticed that the lens shutter had moved (to be closer together). I turned it on, and after a few automatic adjustments, the camera was working like normal again! Perhaps the same thing that broke it, fixed it!
Jan 17, 2009 | Olympus Cameras
Blurry pictures.
Check if everything is fine with mechanical zoom and do factory reset.
Dec 17, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
I lightly dropped my camera on a carpeted floor and now my AF light (the orange light) on my cybershot camera doesnt work. How do I fix it? Do I really need it? Everything else works fine.
As far as I know, the autofocus (AF) light is needed only in lower light conditions to illuminate the subject. You may not be able to rely on it working without having good light available so you should try some shots in poorer light to see if it is really not working before depending on having in-focus snaps.
If you don't use it in low light conditions, you may not miss it.
Dec 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
My MV800 ejects with message "remove the cassette". I have tried both old tapes and brand new one but same message.
I READ THE SOLUTION TO THIS PROBLEM THIS MORNING ON THIS WEBSITE, BUT I CAN NO LONGER FIND IT.
THE SOLUTION SUGGESTED DROPPING THE CAMERA ON TO A CARPETED FLOOR FROM HALF A METRE HIGH AS A FIX.
THERE WAS ALSO A POSTING FROM A GUY WHO HAD FOLLOWED THIS ADVICE AND IT FIXED HIS CAMERA.
SO I DECIDED TO FOLLOW SUIT AND I DROPPED THE CAMERA ON TO A CARPETTED FLOOR FROM HALF A METRE HIGH AND WHEN I TRIED IT WITH THE TAPE IT WORKED, NO JOKE, THIS IS AN HONEST AND TRUTHFUL REPORT.
REGARDS
EDDIEWEST
Nov 27, 2008 | Canon MV800i Mini DV Digital Camcorder
Dropped camera
your batteries will proberbly dead. you should try changing them
Oct 08, 2007 | Kodak EasyShare C653 Digital Camera
Lens does not retact and camera does not work
nova678
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks! IT worked! Awesome! I love this camera of mine and now after three years of ownership it works again! I thought I would try this fix because I have nothing to lose since the cost of fixing the camera would be more than actually buying a new camera.
My problems began when I left my Sony DSC-S60 camera in a very hot car. My genius brother and nephew said the temperture and humidity expanded some of the gears and/or the opening mechanism. They said I would have to take it in for repair or just buy a new one.
I tried new batteries, and jarring and banging the camera somewhat lightly at first on a countertop with no success. I even thought of putting it in a plastic container in the freezer for a few hours to see if I could undue the "heat damage".
At any rate, I just saw this posting and I just dropped it twice on a hard carpeted floor, (truly hard -concrete underneath the carpeting with minimal or no padding) and EUREKA!! It works! It works!!
I might caution those trying this great fix, avoid concrete or tile floors and when you "drop" the camera do so from waist hight at first and try to get the camera to hit on the bottom of the camera, not the delicate front (the lens aperature) fo the camera.
Wow! am I ever happy. My camera back in time for the holidays AND NO MORE LEAVING IT IN A HOT CAR OR OTHER INCLEMENT CONDITIONS!!!! Good luck friends.
Comment by nova678, posted on Jun 30, 2008 Thanks! IT worked! Awesome! I love this camera of mine and now after three years of ownership it works again! I thought I would try this fix because I have nothing to lose since the cost of fixing the camera would be more than actually buying a new camera.
Aug 30, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
118 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
