Question about Panasonic NV-GS120 Mini DV Digital Camcorder
Video Camera not being recognised by computer
My computer has always worked fine with my vcam but suddenly I cant get my computer or other computers (I have tried a few) to "see" my camera. There is no bubble that comes up saying that the device has been found and I have tried a few programs to locate it with no luck. I can still watch my tapes on the tv, but it just seems like its the firewire that isnt working. I have also tried a few firewire cords and have hooked up friends vcams to my computer (that have worked). Help please.
SOURCE:
  • 473 Answers
SOURCE: HELP ME FIGURE OUT HOW TO DOWNLOAD VIDEO TO MAC...
I use a DV camera that is not on Apple's "compatibility" list. (It should REALLY be noted that Apple sells camcorders in it's on-line store that aren't listed as compatible!) Depending on which software package you are using, including version, results may vary. I too had a fairly confusing frustration the first time out, but here's Jeffe's notes: FireWire! (USB is not for video). Start with iMovie: (FinalCut is higher-end, and thus is more picky about what it will take.) launch the application, then plug in the powered-on camera set to it's "play" (VCR etc.) setting (as opposed to camera setting.) If iMovie STILL does not see the camera, then I'd start to worry about compatibility, and contact an Apple SPECIFIC retailer (not a chain, like CompUSA etc.) for help. BTW: Nice Camera! Let me know if it works out. I was contemplating Panasonic for my next camera.
Posted on Sep 06, 2005
Quack
  • 542 Answers
SOURCE: putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Posted on Sep 15, 2005
Basti
  • 1447 Answers
SOURCE: panasonic pv-gs150 mac connection
For Macintosh
OS:
Mac OS X v 10.1–X v 10.3
CPU:
iMac, iBook or Power Book G4, Power Mac G4 or
Power Mac G5
RAM:
64 MB or more
≥The USB equipment operates with the driver
installed as standard in OS.
Posted on Apr 11, 2008
SOURCE: Panasonic PV-GS31 video to PC trouble.
The usb is only used for the still pics and for the webcam. You need a DV cable to upload vid.
Posted on Sep 24, 2008
RixsFixes
  • 2200 Answers
SOURCE: Inability to download video from Panasonic VDR-D150 camera
Hi
On this camera you need to go into the menu and select USB function and tell it to go into PC mode.
Otherwise the USB is in printer mode and the PC will not recognise it.
I am not sure if you got a manual with your camera so I have included this link for your convenience where you can download it.
http://support.panasonic.be/shop/data/User_manual/Movie/IM_VDR-D150EB_UK.pdf
The manual is not very clear on this instruction but see page 94 for a reference to what I mean.
Hope this helps. Please do rate this answer. Thanks.
Posted on Aug 28, 2009
Testimonial: "Thank you very much. I will try your suggestion and give you the feedback. Bernice"
Mac does not recognise my camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto or Nikon Transfer.
Jul 02, 2012 | Cameras
My computer cant recognise my camera at all
The thing to do is to go back to Canon at:-
http://www.canon.co.uk/Support/index.asp
Feb 28, 2010 | Cameras
Panasonic Lumix DMC-TZ5 does not recognise my memory card
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the instructions.. 3. After downloading any pictures from the card, insert it into the camera and do the "format" thing again. everything should work now. Remember, never use the computer to format or erase your card...always use the camera. Also, when removing the card from the computer, always use "safely remove hardware" icon at the bottom right of your computer screen.
Feb 16, 2010 | Cameras
Not recognising USB
To remove the message, press MENU/SET. You can also eliminate any problems by using a separate card reader to download your pics to a folder you create on your desktop.
Dec 15, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Canon mv700
Hi
I have had this camera for around 4 years now. It works fine. I basically plug in the firewire connection on my camera switch it on to playback/camera mode then plug the other end into to my computer my operating system picks it up fine without any problems. It doesn't require any drivers windows will auto install any drivers it needs. Not sure why you are getting this problem.
Nov 09, 2008 | Canon MV700 Mini DV Digital Camcorder
I need drivers for JVC GR-Dv500 camera
GR-DV500 is a miniDV vcam w/c must be FIREWIRE**-connected to a pc to upload video thru video capture or video editing* application while vcam is on playback. Before cable** purchase, note: Firewire port of vcam is 4pin...check the firewire port of PC whether 4 or 6 pin. http://en.wikipedia.org/wiki/Firewire
Normally, the drivers are bundled with your computer OS, such that when the vcam is connected, the vcam is recognized by the video editing programme.
For starters, free Windows Movie Maker* (XP-wmm2 & Vista-wmm6) provides simple & easy way to learn the ropes < click help for details>. Upgrade to other video editing app http://video-editing-software-review.top... accdg. to need & skill level
Video Editing Process
>>> open wmm- start/all programs/wmm->TASK pane
..Step 1. Capture/Import video files (+pics, music) to be edited
..Step 2. Edit- drag/drop files->timeline & enhance w/effects, transition, music & titles
..Step 3. Finish (render)- save Movie file, also save Project* file
..Step 4. Share-burn to CD (to DvD thru a DvD authoring app)
Jul 11, 2008 | Cameras
Vcamnow2.0 drivers
can somebody give me the sites or can direct me to the site where i can download drivers for my webcam... my webcam is V-CAM... thank you
Jan 13, 2008 | Tiger Electronics VCamNow Flash Media...
Video camera to laptop
Yes you would need to install a driver. Did you receive a software disc with your vcam? If not, you can get the driver from here.
Dec 16, 2007 | Video Cameras
Camera not recognised when connecting to computer
playing the recorded dvd on your computer may be simpler , because your camera does not have a firewire connection for editing .
Aug 25, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Pentax option 430 camera problem
Bassie - did you resolve this? My computer recognizes the camera just fine. I have photos on my card but when I try to download to my computer, I don't see any photos. I've emailed Pentax several times w/ no help to this problem. Do you have automatic MS updates set on your machine? What Virus protection do you have? I've run into problems w/ another program conflicting w/ virus protection software.
Apr 24, 2007 | Pentax Optio 430 Digital Camera
Panasonic NV-GS120 Mini DV Digital Camcorder Logo
65 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
