Question about Refrigerators
My fridge is blowing hot air the compressor will not kick on
  • 76 Answers
Check the start relay on the compressor
Posted on Dec 31, 2008
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Whirlpool ET18JK Not cooling, fan runs, compressor kicks on, blows hot air?
Easy tests, put your hand on the compressor, if it is vibrating it is running. Touch the two lines coming out of the compressor, if they are both warm then the valves are shot on the compressor, if they are just regular temp then you have a refrigerant leak, if one is hot and the other is cool then you may have a blocked cap tube, which means a $600 fix. If the compressor isn't turning on I would check the thermostat for bat contacts. When you set it to low there should be a small ammo unit of resistance and if you turn it off the meter should say OL. Good luck
Sep 04, 2012 | Whirlpool Refrigerators
A/C stopped working and blowing hot air. Is there a fuse to check?
In almost every case, when hot air blows while AC is turned on, it's an indication the system is low on refrigerant. This could be due to a leak in the system. There are do-it-yourself kits sold at most auto parts stores or a qualified service station can recharge your system (they have to check for leaks prior to recharging the system).
If you can hear the compressor kicking on and are still getting hot air, check coolant level. If coolant level is good and compressor is kicking on, you may need to change out your thermostat.
Aug 05, 2011 | 2005 Honda CR-V
Hot spots on outside of Amana fridge. sxd22s2w model
if it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that too.you might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close together.you can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
May 22, 2011 | Amana Refrigerators
Air conditioner blows hot air fully charged with
compressor or receiver/dryer or condensor may need to be replaced. Further testing will have to be done. Look into your sight glass and see if there is any bubbles in the glass, or if glass is extremely foggy. If so, you may have air in the system. Check to make sure you are getting power to the compressor.
Jul 20, 2009 | 1995 Lincoln Town Car
Blowing hot air. Compressor not kicking on. Where
Possibly three things, either a thermostat problem, starter relay/capictor, or a bad overload protector not closing after an overload. The starter relay should be behind a black box located on the side of the compressor.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Why does my freezer work but my refrigerator doesn't?
my westinghouse fridge
the freezer is working but not the fridge
Feb 05, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
434 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
