Question about Refrigerators
Refrig door squeeks when opening & closing
The noise comes from the part in the door.
  • scotthursh Dec 31, 2008
    Side by side. I tried that and it did not help. The sound seems to be coming form inside the door. I think there is some kind of closer inside the door.
  • 76 Answers
Is the refrigerator a top & bottom, or side by side. Never the less, you need to apply some white lithium grease to the contact points of the hinge. where thr hinge meets the door get a q-tip, and apply the grease
Posted on Dec 31, 2008
  • Duane Grant
    Duane Grant Dec 31, 2008
    is the refrigerator a top & bottom, or side by side. Never the less, you need to apply some white lithium grease to the contact points of the hinge. where thr hinge meets the door get a q-tip, and apply the grease
  • Duane Grant
    Duane Grant Jan 02, 2009
    is the door spring loaded, does it close by itself?
Squeeks!!! When the door opens or closes it squeeks very loud. WD 40 and other similar products have nott helped.
WD 40 is a water displacement formula not a lubricating product.
Try a oil hand pump with some light engine oil on the henge directly.
After a few days this should help.
Hope this tip helps.
Jan 23, 2010 | 2002 Oldsmobile Alero
Sounds like drum squeeking, have to open and close front door to get even one page to print
There is also the fuser unit that need regulare servicing because the majority of the squeeking comes from the fuser unit because of the generated heat.
Good luck
May 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
The oven door squeeks
lol sounds like its not just a lube problem but an alignment problem. alot of times the hing has a nylon bushing to cut that noise out. might just want to remove the hing and replace it or try to find a new bushing. these type of problems really ****. seems simple to fix yet it offten takes months of trial and error to cure the problem..... good luck
Jan 14, 2009 | Jenn-Air JES8750 Electric Kitchen Range
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
Jan 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Belt Noise for Chamberlain HD600 1/2 HP Whisper Drive Garage Door Opener
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
Jul 29, 2008 | Electrical Supplies
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Sub-Zero 550 Fan Vibration
you could try taking the fan assembly out and adjusting it or oiling it, sometimes it gets that back pressure when the door is closed because it has to work harder
Jan 20, 2008 | Refrigerators
Dec 02, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
