SOURCE: Central locking on volvo 850 1996
Happened to me after first purchasing my 850 - check the fuse for the CLS, as mine (for some reason) was too narrow, and was jostling about. Once I changed it out for a new fuse, no problems at all (I performed this fix a year ago, and no problems since).
SOURCE: REAR DOOR LOCK
you either have a faulty central locking motor or the wiring harness may be damaged.
Remove the door panel and check if you have a live feed to the central locking motor when you use the fob to lock or unlock. If you have power, then it will most likely be the motor that is at fault.
SOURCE: interior electrical problem
apply for ALDATA on the internet ,its only like 25 bucks and you will be surprise how much information you can get you would not need a mechanic again
SOURCE: Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
SOURCE: auto door locks 200 volvo S70
You may have a bad master door swith assembly or more fuses out.
