Question about Refrigerators
Door squeeks when opening & closing - Refrigerators
    President:
  • 2,692 Answers
Spray silicone lubricant, which comes in a can, on the top and bottom hindge pins.Wipe off excess.
Posted on Dec 31, 2008
The door has a loud squeek opening and closing
Oil the hinges with some 3 in 1 oil or equivalent.
Dec 03, 2011 | KitchenAid Dishwashers
Tip
How to stop a squeek
For fixing A squeek on your fridge door/kitchen doors/stove door/microwave/or even car try this and save money.We all have cooking spray and if you don,t buy some before the hardware store sells you something that will cost A fortune.Just spray A small amount on t5he squeek and open and close it 4/5 times. If it is hard to get at use A small paint brush.This can also be used on all most anything even your car but only in the summer because it will freeze.Now the squeek is gone and you can use the rest for cooking no waist.Thank you and good luck....
on Sep 25, 2014 | Oops Cleaners Ready To Use Spray 500 Ml
Squeeks!!! When the door opens or closes it squeeks very loud. WD 40 and other similar products have nott helped.
WD 40 is a water displacement formula not a lubricating product.
Try a oil hand pump with some light engine oil on the henge directly.
After a few days this should help.
Hope this tip helps.
r/
David
Jan 23, 2010 | 2002 Oldsmobile Alero
How do I keep the door from squeeking when I open or close it?
Lithium grease or lubricating silicone spray.
Sep 16, 2009 | Dishwashers
Sounds like drum squeeking, have to open and close front door to get even one page to print
There is also the fuser unit that need regulare servicing because the majority of the squeeking comes from the fuser unit because of the generated heat.
Good luck
May 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Drivers door window squeeks when it is opened.
before removing anything, try spraying some graphite spray down the side tracks of the door frame where the glass rolls up and down. do not spray the felts that go cross ways
Apr 26, 2009 | 2005 GMC Sierra
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
The oven door squeeks
lol sounds like its not just a lube problem but an alignment problem. alot of times the hing has a nylon bushing to cut that noise out. might just want to remove the hing and replace it or try to find a new bushing. these type of problems really ****. seems simple to fix yet it offten takes months of trial and error to cure the problem..... good luck
Jan 14, 2009 | Jenn-Air JES8750 Electric Kitchen Range
Refrig door squeeks when opening & closing
is the refrigerator a top & bottom, or side by side. Never the less, you need to apply some white lithium grease to the contact points of the hinge. where thr hinge meets the door get a q-tip, and apply the grease
Dec 31, 2008 | Refrigerators
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
