Question about Sirius Satellite Radio Sirius SIR-ALP1 Satellite Radio Receiver
Receive "Antenna Fail" on receiver
When the weather gets cold I get a "antenna fail" message on my factory Mazda CX-7 radio for satellite signals only. The AM/FM works fine. After about 10 minutes or so the satellite radio signal comes in and is good for the rest of the day even if I park it in the cold for hours. The antenna has been replaced twice. The antenna splitter is the original. The Sirius receiver itself is mounted on the rear inside fender well . The antenna is a rear roof mount. In the summer it works fine even inside a garage. Could it be the splitter? On this radio its a small box with the antenna wire plugged in on one side and two short plugs on the other side plugged in to the radio. It's seem unlikely that a solid state radio would have to warm up to get a signal. Any suggestions would be appreciated. Thank you
  • mrsmith93 Jan 21, 2009
    I'm having the same problem with my Mazda CX-9. Any suggestions would be greatly appreciated, as the problem has now deteriorated to it taking an hour or more to receive signal.
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Posted on Dec 11, 2009
I have a cobra 29 LX Max that I hooked up and everything passed. I later changed the power cord and now it says antenna fail when running test and antenna warning when I key up. I can receive,transmit
That is odd. I would unplug the unit. Now unscrew the antenna and check the connector attached to the coax. If you can unscrew the antenna, use a continuity meter and test the cable with the connector. Sometimes connectors whether installed by you or a factory simply fail, or the solder fails. You may need to replace or resolder the connector. Best of luck and post your results.
Feb 12, 2017 | Cobra Radio Communications
What is wrong with a satellite reciever when all I am getting is aquiring signal displayed
This indicates that the antenna is not gathering enough of the signal to be played. This can be caused by an obstruction between the antenna and the satellite in the sky ie: tall buildings, heavy tree cover, covered garage, etc. It can also indicate a problem with the antenna itself, the cable between the antenna and the radio, the connector on the end of the cable or in the radio or, a problem with the antenna circuit inside the radio.
Since there's little you can do about the last item in the list, check the other parts of the antenna for damage. A pinched or crushed cable will short out the antenna signal - and the voltage sent to it by the radio. If allowed to persist for very long, damage to the radio could result. Look for breaks in the outer jacket of the cable - water entering the cable will cause corrosion and will degrade the signal, too. If you find a problem with any part of the antenna system, about the only thing you can do is replace the antenna completely. You can get a replacement online for as little as $9 and change.
Before installing, try connecting the antenna to the radio with the antenna exposed to ta clear view of the sky in a location that you were able to receive a signal before. If it works, you're done. If it doesn't - the problem is internal to the radio and will need to be repaired - or replaced.
I hope this was helpful - if it was - please rate it "4 thumbs up" Thanks!
Aug 02, 2011 | Sirius Radio Receiver
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
I have a Uniden 525 fixed mount 2-way VHF radio. It has power and picks up weather with the shakespeare antenna. However radio checks have failed and i don't receive anything either. The antenna's tip is...
Yes if the tip is broken, the antenna will receive, but not transmit properly. The make an antenna that has a 32" stainless steel antenna with a small metal "can". Can mount it anywhere.
Mar 28, 2011 | Uniden UM525 ES Series VHF Radio with...
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
If it is reading "ACQUIRING SIGNAL" WHAT CAN THIS MEAN??
This typicall represents a failed antenna with either a loose connection or failed wire to the antenna. The "Acquiring Signal" indicates the receiver is trying to locate and decipher a signal from a sattelite. THe antenna is your first diagnostic. After that the receiver is the culprit. When your receiver is Activated or Authorized it is given a "key" to decipher the sattelite signals If it loses the "key" you can try and have Sirius reinitialize by contacting support. If they cannot send the signal and get the proper "Key" loaded its a defect in the receiver functionality.
Jun 15, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
XM radio reception issues
If you have the magnetic antenna, check it for a little nick on the cable on the outside of the car where water might get in to it. A little water can short the ground and the antenna wire. You also can wash (with lots of water around where the antenna cable is) and see if it happens again, then you will know it not just the weather
Mar 05, 2009 | XM Radio Audio Players & Recorders
"no antenna" message
it could be the wire that connects from the actual antenna and the radio. Even if it is new it might just be wrong from the factory.
Jun 10, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
No antenna detected
i had the same problem and had to return the antenna to radio shack to get a replacement. the guy said that the antenna had a crack in it from the cold weather or water got into the antenna and that is why it malfunctioned.
Feb 06, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Satellite Radio Sirius SIR-ALP1 Satellite Radio Receiver Logo
485 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
