Question about LG DLE2532W Electric Dryer
Dryer does not produce any heat. All controls and drum rotation are operational. Power and circuit breakers are fine.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls check:
  • filter, filter sensor could be checked with a continuity tester;
  • thermostat, thermal cut-off, likewise could be checked with a continuity tester;
  • heating element itself, same continuity check.
This page would show you parts.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Dec 31, 2008
  • 177 Answers
Hello and welcome to FixYa!,
It might be the Heating Element in the Dryer that has died, This will happen over time to all Dryers and your best ption is to replace it with a new one!
Hope this is your FixYa! --P3NGYJ03
Electric dryer is not producing heat
Check your power source. In the circuit breaker box for your home there is a breaker for the dryer. It consists of 2 identical breakers combined into one. Some have a rod connecting the handles together so when one trips so does the other. Some only have one handle that trips both. These breakers sometimes trip one but not the other. That can be the reason you have motors running but no heat. If you have a voltmeter you can check the voltages at the wall plug for the dryer. There are 3 (some times 4) blades on the cord. The 4th blade on the cord is connected to the metal case of the dryer.Unplug the cord and set the voltmeter to check 240 Volts AC. Now insert each test lead into the two outer slots of the plug that look like V shape. If there is 240 volts present then the problem is inside the dryer. If there is not 204 V AC present move one of the test leads to the middle connection. Do this between both of the outer slot and the center to test both breakers If you get 115 volts AC, you'll need to replace the circuit breaker.
Sep 25, 2014 | Dryers
The dryer will not heat up
Instructions
    • 1 Check the cycle selector control to make sure a heating cycle has been selected. The selector should be in an "Off" position when not in use, but it should be turned to a drying cycle when in use. On some models, make sure you are not accidentally running the dryer on the "Air" cycle, which does not use heat.
    • 2 Check the gas supply valve to make sure it is open if your dryer is a gas dryer. If it is not open, just lift the valve open.
    • 3 Look at your house's main breaker box to determine whether a circuit breaker is tripped. The electric dryer runs on 220-240 volts and has a double breaker. If the breaker for the heating element is tripped, the drum may tumble the clothes without heat. Turn the dryer's breakers to off, then back on; test whether the dryer will produce heat.
    • 4 Consult a technician if troubleshooting does not resolve the problem.
Jan 15, 2013 | Kenmore Dryers
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
Feb 18, 2011 | Dryers
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
Dryer does not heat up.
The following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, generally, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. I hope you find this information helpful.
Sep 25, 2009 | Kenmore 84072 Electric Dryer
Replaced coils / looks good and produced heat but now no heat
caused a short maybe ,reset circuit breaker and check 4 wire against frame
Aug 23, 2009 | GE Dryers
No heat, dryer runs fine it will not heat up. vent is clear all the way to the outside. I think it may be the fuse but I don't know the location, can you help?
hi..
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair...
thank u
rate me
Aug 18, 2009 | Kenmore Dryers
Kenmore Dryer model # 60202990.... no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Sep 13, 2008 | Kenmore 62872 Electric Dryer
Hotpoint Aquarius wd640p
Heating element
Thermal fuse
Wiring
Aug 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer drum wont turn
These units use two circuits to operate. It is entirely possible that the circuit breaker for one is open. The breakers are linked units...generally 30-40 amperes. Turn both off and then on.
Dec 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
LG DLE2532W Electric Dryer Logo
20 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
