Question about Gateway Computers & Internet
Loss of internet, blue tooth light wont turn back on
I was on the internet, then i lost my conection. at first i thought i was just a bad connection, but after i checked my wireless modem, the connection was fine. i then noticed my blue tooth light was off. and i still cannot get it to turn on. even though the switch is in the on position, i have tried moving the switch on and off, restarting my computer and waiting to see if it was a temperary problem. but nomatter what i do i cannot get my internet to come back on. i need my internet for my work, so please help me.
    Problem Solver:
  • 8 Answers
Here are some things to try. I would remove the bluetooth adapter. Is it built in? If so, you will not be able to do this. If it is an adapter take it out and try putting it back in. Did you install new software? Do you have anti-virus? I would recommend that you do a system restore to the point of when it happened. The system restore will restore the settings previous to the incident. Now the next thing is to do a right click of the system and go into properties. Depending if you have Vista or XP the Device Manager will be in different spots. Look in the Device Manager and uninstall the BlueTooth. Reinstall the device. If the BlueTooth is built in then you will probably have to contact tech support at Gateway.
Let me know if you have any other question.
Posted on Dec 31, 2008
I cant open the icon of my bluetooth device that is why i cant conect to wifi? how to open it what is the best way to do,, to open so that i can conect wifi,, thankyou..
If your blue tooth is Usb type try to remove and replug it again,then you will observed that there is a blue tooth icon appear to the lower right corner of your computer, it means your connected or check it out to MY computer,look for the blue tooth icon. Right click the icon then choose what connection you want.
Jul 22, 2011 | Computers & Internet
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
No internet connection
if you are worried about the icons that are sown in the tray system ( lower right in the task bar ) those are showing the other connections that are not working at the time ...for example the LAN cable conection ...and the blue tooth ..those will appear not connected if you have no cable on the Lan card or blue tooth device connection ...even if you are connected via wireless those will appear unless you choose to unchecked the show in tray ...
if you are asking about the connection you have made wireless and it doesnt work ...you probably have a driver problem ..just reinstall the driver for the wireless card if you know that the connection should work ...if you have acces on the net wireless those icons that are x-ed on the right on the task bar are for the other connection methods ..so do not worry ..
Jan 06, 2010 | Sony VAIO VGN-CR320ER Notebook
How do you connect a bluetooth mouse to this laptop?
AS far as I am aware this model did not have blue-tooth just regular
Wi Fi
If you got a blue-tooth adapter with your mouse then plug that in to an available usb port on your laptop and then install the software that should have come with the mouse.
Aug 24, 2009 | HP Pavilion dv7-1132nr Notebook PC
Hi and Assalam Alaikum ! How can I use the Blue tooth tehnology in DEL INSPIRON 1501 MPDEL and connecting to the internet Automatically
First you can needed a blue tooth enable mobile handset . then you can use gprs pack .then conect gprs via bluetooth.open the Opera browser then scynorise it then conect.
Mar 06, 2009 | Dell Inspiron 1501 Notebook
6630bluetooth prolem
FIRST OF ALL RESTART YOUR MOBILE PHONE. THEN TURN ON YOUR BLUETOOTH CONNECTION ON YOUR PHONE. ALSO SET YOUR PHONE VISIBILITY ON FROM YOUR MOBILE BLUETOOTH MENU.
THEN TURN OFF YOUR BLUETOOTH DEVICE. NOW PRESS AND HOLD THE POWER BUTTON ON YOUR BLUETOOTH DEVICE. WHEN THE LIGHT BLINKS YOUR BLUETOOTH DEVICE IS DISCOVERABLE FOR YOUR PHONE.
NOW SEARCH FOR A BLUETOOTH DEVICE FROM YOUR MOBILE'S BLUETOOTH MENU. YOUR DEVICE WILL BE DISCOVERED BY YOUR MOBILE. NOW ADD THE BLUDTOOTH DEVICE TO YOUR MOBILE THE PASSCODE SHALL BE 0000 OR 1111.
NOW YOU CAN USE YOUR BLUETOOTH. IF STILL UNBALE TO EXCESS PLS. ASK US.
PLS. RATE MY SOLUTION.
NICE DAY
REGARDS
KETAN PATEL.
Feb 12, 2009 | Nokia 6300 Cellular Phone
Conecting blue tooth
You did describe the full question.
If you have facing some problem while connecting via blue tooth check you these sittings
you phone have name in blue tooth
your phone should be visible on
And you should one it while connecting to any device then you can search for any blue tooth device.
Let me know if you have any other question regarding this topic.
Nov 18, 2008 | Cell Phones
Bluetooth
first switch on the blue tooth on your black berry and then connect blue tooth dongle to your computer and check if the connection is established in your computer , blue tooth dongle is usb device ...
Good luck.....
Nov 01, 2008 | RIM BlackBerry 7290
Bluetooth conection
you have to activate blue tooth connectivity on your phone
Dec 02, 2007 | Toshiba Tecra A8-S8514 Notebook
Computers & Internet Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
