Question about Pioneer DEH-P6400 CD Player
No sound My girlfriend had this mounted in her old car when she had the dealer remove it for her and i went to put it in everything worked but no sound.I double checked the connections and everything seemed to be in good order.it's not the car cause we put an alpine in and it worked fine.?????????????????????
  • lwholloway Jan 20, 2009
    i just brought a new harness cause i thought it was the harness why i didn't have any sound to any of my speakers, the speakers are new they work with the other radio i have which is a pioneer deh- p3100 and that radio does not power on now.. but all of the connections are fine on both radios and it use to work fine!
    Genius:
  • 1,224 Answers
Proper wiring harness color match colors to wire harness when wires get old they fade sometimes you have to really look at them im thinking you got faded wires dirt will do that the speaker wires are as goes from top from power and ground 2 sets for fronts on top row first bottom yellow memmory then antenna remote rear 2 sets of wires wire harness should be the same if not check
Posted on Apr 21, 2008
    Problem Solver:
  • 19 Answers
See solding points of the conectors in the radio and if the MOSFETis good(see if it is hot)
Posted on May 06, 2007
  • Helder Luis
    Helder Luis Jul 03, 2007
    are the speakers ok?
SOURCE:
Hello my girlfriend owns a 2002 Toyota echo 5 speed we bought it used she has put bout 4000kms on it since then. A few days ago now that its cold around -10 she started the car and the rubber gasket around...
If oil pressure is too high, check if the pressure relief valve is stuck or inoperable.Don't know where it's at on your toyota. Check with a garage or dealer for location. Other possibility is a clogged oil passage somewhere. For that, a good oil conditioner might help.
Dec 30, 2012 | Cars & Trucks
How to change a EGR valve
As I recall this looks like a morelle mushroom, big as a man's thumb, and is mounted vertically near the top rear of the bell housing area. Remove the battery cover and the negative battery cable. Unplug the thing, unscrew the two bolts, clean both metal surfaces of all gasket material, put some gasket goop on both surfaces of the new gasket, put the new one in, screw down the bolts, hook up the wiring, etc. I actually paid a small shop to put one in mine, I provided the parts. When I went to pick it up the new gasket was still laying on the seat, I asked the guy about it and he told me the old gasket was good. I could not believe that a paid mechanic would pass on a new gasket when replacing anything. The SES light was still on, I drove it home and did the job myself the next day doing the necessary cleaning and using the new gasket. It has been two years the SES light has never come back on and my girlfriend still drives the car. I never used that shop again.
Nov 06, 2010 | 1999 Saturn SL
Speakers don't work
If you had followed the directions correctly and the old speakers worked as well, take the new radio back for exchange
Jan 18, 2010 | 1990 Nissan Maxima
2005 Honda Accord Dashboard Noise
try inspecting the front side and rear engine mount
Mar 28, 2009 | 2004 Honda Accord
2003 tiburon electrical
I would first check the head light switch which I believe is the same as the turn signal switch or combo switch on the column. see if that is getting hot and cooling off. The fuse panal or Body Control Modual is about $1000.00 and the Combo switch is $80.00 at Autozone. and is easy to put on.
Mar 14, 2009 | 2003 Hyundai Tiburon
Kenwood hac 9152d, was working fine now doesnt output any sound
Check the fuse on the amp.
My girlfriend had the same thing, light was on, no sound whatsoever. The fuse on the amp had blown, but I'm guessing some current must have made it through to just put the light on. Make sure you have a 40 amp fuse in it, that's what it needs.
Good luck
Dec 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Blackberry trackball wont work
Buy an iPhone, they don't have hokey trackballs.
Sep 29, 2008 | RIM BlackBerry Pearl 8100
Valve body
it is not put in tight enough , or it is aligned incorrectly with the mounting position.
Jun 18, 2008 | 2006 Infiniti G
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
My xbox 360
Damn if my girlfriend did that, it would be on.
Heres what you do:
Its only 3 months old, call 1800-4my-xbox they can replace it. Don't tell your girlfriend broke it, tell them the red lights started one day.
They wil lship yuo box, you put eh box inside the box they give you, you ship it back to them, they ship you a brand spankin new 360.
If for some reason they refuse to replace it you can pay to have it repaired at:
http://www.xbox360-pros.com
Good luck,
Cam
Oct 19, 2007 | Microsoft Xbox 360 Console
Pioneer DEH-P6400 CD Player Logo
350 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
