Question about Konica Minolta magicolor 2400 Laser Printer
Toner will transfer to the transfer be
Minolta 2300w . all the toner will transfer to the transfer belt , however it won't go from the belt to the paper . Also when the paper comes out it stops about 1 inch from the end and I get a paper jammed message . I open and close the doors and it will try and print again . then does the same thing . the printer has 44k of pages it has printed and a ned transfer drum . Can anyone help ? I called Minolta and they said it was a fuser problem . The fuser is hotter than heck and well I just don't think it could be that , Doesn't make sence to me .
  • azcenter Dec 31, 2008
    the way this printrs rollers are set up . The toner goes from the drum to the transfer belt . after it reaches the transfer belt it is suppose to be via static discharge sent over to the paper and then the paper goes up through the fuser rollers to melt it down . So I guess my problem is in the discharge process . and the printer is a magicolor 2300w
    Master:
  • 461 Answers
As I understand it from servicing laser printers, the toner is actually drawn statically to the paper from the drum by a charge on the belt. Toner is not supposed to be distributed to the belt. The fuser fuses the toner to the paper after the transfer. Can you access the fuser rollers to see if there is any sign of wear or damage they may be keeping the paper from entering it properly? The toner on the belt is probably excess from the paper not being pulled through and having the toner fused properly.
Posted on Dec 31, 2008
Konica minolta 2300w change toner
You will find the step-by-step procedure on the following link, on the page 57 (48)
http://printer.konicaminolta.net/drivers/manuals/2300w/user_es.pdf
If you need anything else, let us know.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 21, 2014 | Office Equipment & Supplies
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
There is no error message but the pages come out very weak and the more copies you make the lighter they become
Might be one of these things:
If somebody reset a cartridge back to say it is full at 100% full and the toner is actually running out.
Or you might have a problem with your Transfer Belt, my Transfer Belt on magicolor 2300w was printing weak and faded, as if the print was washed out looking, after a bit of research I removed the Transfer Belt and cleaned it with ISOPROPYL ALCOHOL (it's almost 100% alcohol), replaced the same transfer belt unit and it prints fine again.
Oct 14, 2009 | Minolta magicolor 2300W Laser Printer
Konica 2300w jams paper on the fuser unit.
the lubrication for the fuser roller comes from the KM toner. There is usually a cleaning roller in the fuser as well that distributes some oil. Another thing that could cause the problem is non-recommended paper like heat transfer paper, inkjet photo paper or very thick paper. Make sure the fuser sperator teeth are still in place. Lift the two green levers and pull the black cover back. You should see three light brown teeth hovering above the fuser roller. There are some black ones on the guide as well. These are supposed to detatch the paper from the roller incase it sticks.
Aug 05, 2009 | Minolta magicolor 2400W Laser Printer
Replaced Black TOner but still says it is empty
One way you could reset the toner is using the service mode.
Is this printer a 2300w ? If so, open the front door of the printer, turn on and hold down the cancel button for at least 20 seconds, that resets all the counters to factory defaults. The only problem is, that it will set all the toners to 100% and standard capacity, but you can change that in the software. One good thing is, it sets the OPC drum,
Fuser unit, transfer belt, everything to 100%
Delboy
Jan 26, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Won't transfer from the transfer belt to the paper
Where is the Transfer roller. was that replaced also when replacing the transfer belt ITS a SPONGE LOOKING ROLLER same lenght as the width of the belt
May 03, 2017 | Konica Minolta magicolor 2400 Laser...
16H means, that the transfer belt does not rotate correctly, open all covers, remove any paper, whats stack inside, remove waste toner box, drum unit then open 2 nipple screws and pull out the transfer pelt, if the belt looks ok, reinstall everything and power on again. if works, then everything is ok, if not, then there is something wrong with TBU or TBU
Nov 14, 2007 | Minolta magicolor 2300W Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
249 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
