Question about GPS
Hi i'd like to know how to update the maps this uses navione app. Thanks
  • 27,725 Answers
Which device ?
Cobra NavOne 3000
Go to the Cobra website (see Resources) and click on "FAQ" at the top of the page.
Use the drop-down menus to select "Nav One 2750-2950-3000-3080" and "Software Updates." Click "Submit."
http://reviews.cnet.com/car-gps-navigation/cobra-navone-3000/1707-3430_7-31138256.html
Click "How do I get and load software updates?" Click the bold "HERE" link.
Scroll down and click "Nav One 3000/3080."
Click on the latest update link to download the update to the computer.
Connect the NavOne's power but do not turn it on. Connect a USB cable to the computer, and connect the other end to the GPS.
The GPS device's LEDs light up, indicating a connection.
Double-click on the update file you have downloaded.
Click "Next" until the update begins.
When you are notified of completion, close the update
hope this helps
Posted on Oct 11, 2012
2 Suggested Answers
SOURCE:
SOURCE: Will not recognise navionics chart
take the chip out and put it back in why the unit is on
Posted on Sep 14, 2008
I have an aftermarket radio/navigation system in my truck. when I hit the navigation button it is looking for the following. \storage card\navione\navione.exe,check sd card. my card is blank
You have a defective NAV system, pull it out and send it in for repair or.... Just use your cell phone's Google maps app for navigation, it is far better then any car nav system.
Aug 11, 2016 | 2014 Ford F-150
Will the hds7 gen 2 read navionics lake map?
Yes, all Lowrance products will use and display Navionics map data.
Compatibility Guide America
Here is a link to the navionics compatability page so you can see which map cards will work in your unit.
Feb 03, 2015 | Lowrance HDS7 GEN2 Insight 83/200KHZ
Navionics maps don't seem to work on my lowrance elite 5 chirp
In your menu under CHARTS there is a choice for either LOWRANCE or NAVIONICS. Select NAVIONICS and you should be able to see your chart maps.
Jan 20, 2015 | Lowrance Boating
My IPad worked well with Navionics untill few days ago, then following problem appeared: when running my boat with trolling speed ( like 2 mph) the screen shows my position on map with the red arrow and...
Go into Settings - Navionics App and make sure that Mobile Data is enabled and also Background App Refresh. Finally, Location set to Always. It sounds like it is not being updated, but just setting your position on opening.
It is not a particularly good app and very basic although I have not tried the Paid version. I have a Humminbird 998 HD Side Imaging and the Navionics Mappind SD Card which gives much better results.
Aug 05, 2017 | Lands Phones
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
Classic Navionics chip in a Furuno 1833C
Gold Navionics is really not bad at all, but by todays standards, lousy. This is a VX1 unit and the classic cartography is frowned upon now, but in the day, this was quite good. So you have to ask, is it worth replacing for cartography alone? Radar and Sonar will plug and play to an 1834C, which is available with C Map or Navionics. Furuno 3D, on the other hand, uses the hyper cool Map Media 3D cartography with sat images and all that, plus other cartography too.
Aug 31, 2008 | Navionics CLASSIC MMC US835L SOUTH FLORIDA
Navionics gold card & humminbird 78c2
Hi!
You NEED to have a gps lock in order for the card to show it's true potential.
Also check in the menu for a setting that says "Map detail" and change it to all available. It could be the setting is on a lesser choice (like the internal mapping and not the new sd card)
Hope this helps!
Mike
Aug 06, 2008 | Navionics: Gold+ Chart Cartridge
Navionics gold sd card
Make sure that you go into MAP data and select this chart as the map info. You might just be using the internal base map right now.
Mitch
Aug 05, 2008 | Navionics Gold United States East...
GPS Logo
449 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
