Question about Sony Playstation 3 (PS3) Console
Corrupt initial setup
It won't get off the language when i go to fix it
    Problem Solver:
  • 7 Answers
Call 800-488-7669
Posted on Jun 15, 2007
SOURCE:
How can I change the language on the panasonic strada cn-dv255rd GPS from japanese to english?
suspect you may have acquired a Japanese (-and-Korean-and-perhaps-Chinese) -language-only model.
But in any case, language changing is usually the first screen on initial setup. If you get a screen of language with two buttons, on the lower left and on the lower right, you probably should select the left-hand button, then select one of (possibly three) languages. English being prodominant, the left-most button of three would be one to choose, if you have a model that can be set to English at all.
The initial setup screen with language choices, will probably be what you get once you reset the device to factory settings.
Aug 21, 2016 | Panasonic GPS
How change language for printer brother mfc-j 5910dw to english
To help you change the display language for MFC-J5910DW Brother printer and copier, please follow the steps given below:
- Press 'MENU' on the printer screen.
- Press the 'UP' or 'DOWN ARROW' on the touch panel to display Initial Setup.
- Press 'INITIAL SETUP'.
- Press the 'UP' or 'DOWN ARROW' on the touch panel to display Local Language.
- Press 'LOCAL LANGUAGE'.
- Press 'ENGLISH'.
- Press the 'STOP/EXIT' key.
If issue persists, please contact Brother Printer Support Center from the link given below:
http://www.brother-usa.com/askus/default.aspx?PGID=5&R3ModelID=MFCJ5910DW
GuruAid.com
May 30, 2016 | Brother Office Equipment & Supplies
32av502u toshiba stuck on initial setup language menu
Sounds like corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given with screen shots illustrations.
Dec 14, 2014 | Toshiba Televison & Video
How do i get back to the initial setup menu on my magnavox MDR535H/F7
Try the following: press Menu and use the Up/Down arrows to navigate to the General Settings. Press OK and then use the same arrows to select Display. Click OK. Again using the Up/Down arrows select Language which should be the item at the top of the list. Make sure that English is highlighted or use the arrows again to select that. Then press OK. Press Menu again to exit the entire menu system. Unfortunately, you will need to navigate through each item from the initial setup individually if any other setting is part of the problem.
Magnavox has the manual for the MDR535H/F7 on their product support page: http://www.m4c.magnavox.com/cgi-bin/cpindex.pl?ctn=MDR535H/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN . The direct link to the manual is http://download.m4c.magnavox.com/files/m/mdr535h_f7/mdr535h_f7_dfu_aen.pdf . See pages 108 and 109 for the Language setting.
I hope this helps.
Jun 24, 2017 | Magnavox Televison & Video
Eror code E000020-02a9
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Aug 02, 2013 | Office Equipment & Supplies
How do I change language settings on my Dell V313 printer
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
How to change language settings
Press the main menu key. Press "settings". Look for "initial setup". Scroll down until you see "language". Press the Language option then change to what ever you want. Not all phones are in this order but once you find the "initial settings" options then you should be able to see the language option.
Apr 07, 2012 | Samsung GT 15503 Cellular Phone
My motorola c350 language has been changed. Now I cant read the language for what its getting difficult to change it to English. Please help
Download the user-manual from this site. http://www.motorola.com/mdirect/manuals/C350_gsm_User_Manual_E.pdf
Observe the menu map. From your main menu, you have to open more (It has box open icon). Under More, you have to open Settings(Two mechanical bolts icon).
Under settings, you have to go to Other Settings which is the 5th option.
Call Forward
Phone Status
In-Call Setup
Security
Other Settings *
Under Other settings, you have the following options:
Personalize
Initial Setup
Network
Car Settings
Headset
You have to select the 2nd setting, that is Initial Setup.
Under Initial Setup, you have the following options:
Time and Date
1-Touch Dial
Backlight
Zoom
TTY Setup
Scroll
Animation
Language
Battery Save
Contrast
DTMF
Master Reset
Master Clear
You have to select the 8the option, which is language(langua/idioma/langue).
Now from the options select English to set english as the changed language.
Jul 20, 2011 | Motorola Mobility C350 Cellular Phone
Wrong language on the LCD display of the Lexmark X6570 how do I fix?
Select a different language after initial setup
1 From the control panel, press Settings.
2 Press left or right arrow repeatedly until Device Setup appears.
3 Press tick.
4 Press left or right arrow repeatedly until Language appears.
5 Press tick.
6 Press left or right arrow repeatedly until the language you want appears on the display.
7 Press tick.
8 Press left or right arrow until Yes appears.
9 Press to save.
Hope that helps, if it does please rate my help. Thanks
Nov 03, 2010 | Lexmark All-in-One Printer with PictBridge
Samsung nv 24 set wrong language on initial setup, how do i fix this please?
Hey herculep,
A graphic example of how to change your language is on page 70 of you camera manual. This is done under the setup menu. I have included a link to a PDF download of your user manual in case you need it. I hope this helps!
http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=75
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Cameras
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
