Question about Philips 26PF9966 26 in. LCD Television
Need to diagnose what board is bad on my 26pf9966/37 lcd tv
I am looking for an educated guess as to what board is bad based upon the flickering of the screen and the screen picture looking like a green sepia picture. I also need the parts list to order the stand bracket that mounts on the units back for the table stand. I have all the parts but the bracket that gets screwed into the back of the unit.
  • jcarb123 Jan 20, 2009
    I am a little upset. I paid 200 for an inverter for my Philips 26pf9966/37. It starts up fine then within 5 to 10 minutes it goes to the attached picture. Does anybody no from looking at this, what piece is failing. Also, after about 30 minutes on the screen goes back to normal and does not turn into thee picture below again.
I have the same TV that went in for repair and they broke the LCD panel before fixing it. I have the stand for it also. My email is umel@charter.net
Posted on Dec 31, 2008
I am looking to sell my internal boards of my Viewsinic N4280P-1M TV. It suffered a cracked screen due to my 2yr old throwing the remote at it, but everything works great. Do you know where I might...
Hi Christopher, where are you located? I have the same TV and am looking for the base stand and original remote if you decide to part it out.
Dec 30, 2014 | Televison & Video
Pana TC-20LA2 LCD TV Blanking Video
Make sure that your input source cables are firmly secured. It almost sounds like a bad input connection that slips over time.
Jun 13, 2008 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Flickering tv
The set will need to be properly diagnosed to determine the cause. You could have a problem with the power supply board, inverter board, CCFL backlight that could be going out, or possible a main board issue. There are a variety of things that could cause this. You don't want to play the "guessing" game on this one. You also may want to google you TV model # and see if there is a history of this problem with your set. Most TV problems are redundant.
Sep 03, 2012 | LG Televison & Video
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
Upper half of screen is flickering. Started last night. Appears to heat up and flicker. When I shut the TV down and let it cool off, flicker stops, but then starts again after the TV is on for a while. ...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 16, 2009 | Gateway XHD3000 LCD TV
I HAVE A VIZIO 55" LCD TV WITH FLICKERING PROBLEM. THEY SAY ITS THE BACKLIGHT. CAN THE BACKKLIGHT BE CHANGED AND WHAT IS THE COST?
More likely to be the backlight inverter board, or the main power supply for the inverter board is bad, power supply is easier to get to than the inverter board, so look there first. Look for burnt parts, bad capacitors.
Nov 10, 2009 | Vizio VF550M 55 in. LCD HDTV
Flashing light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the main power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 06, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Thomson 27LCDB03B
If all the voltages measure normal, the failure could be in the LCD's inverter board. I've checked the schematic and it seems like the 16 volts could be a bit higher, check the electrolytic capacitors filtering the voltage for the inverter board.
Click here to download the service manual.
Good Luck.
Sep 12, 2008 | RCA HD50LPW175 50" HDTV
Philips 26PF9966 26 in. LCD Television Logo
215 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
